turn signal flasher
Old Oct 6, 2006 | 12:27 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
turn signal flasher
I have a '92 RS and I think I need to change the turn signal flasher, when the lights are off and I turn on my blinkers they dont blink, they just stay on. When the lights are on and I turn on my blinkers, the fronts dont do anything and the backs just stay on. Hazards work fine. What does the flasher look like in a '92 Camaro ad where can I find it?
Old Oct 6, 2006 | 01:00 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Are both the left and right turn signals doing this or just one side?The reason I ask is if just one side it's usually a bad bulb.The turn signal flasher,if your '92 is the same as my '83 is located in a convienence center to the right of the steering column(horn relay and key/headlight buzzer is there too).It drops down similar to the fuse box but you have to remove the whole underdash panel.Just FYI the hazard flasher is just to the left of this next to the steering colmn.
Old Oct 6, 2006 | 01:19 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
both left & right
Old Oct 6, 2006 | 10:13 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Since it's both left and right, it probobly is the flasher. The directional flasher for my '92 is secured by a clip mounted to the steering column bracket under the dash - just above the convenience center (fuse panel). The hazard flasher is over next to the center console.
Old Oct 7, 2006 | 12:44 AM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
i changed the flasher, they work fine now.
thanks.
Old Oct 7, 2006 | 07:30 AM
coolram62's Avatar
Engine: LU5 305 CFI
That's great you got them working.I knew there were wiring changes after '88.And on the locations of the flasher units in your '92 they moved other items around.
Old Aug 4, 2011 | 02:23 PM
Pught61's Avatar
Car: 1992 Camaro
Engine: 305 tbi
Re: turn signal flasher
I have a 92 camaro 305 rs and my right blinker doesnt work. ive changed the bulbs, and the lights work just it doesnt flash. my passenger side turn signal bulb is hanging down to where i can see it does it need to go in the lamp part for it to flash? or do i need to replace the flasher?
Old Aug 4, 2011 | 06:07 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'd try replacing the bulb first.
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
