Repeated Ignition Module Failure ???
Old Oct 16, 2006 | 11:55 AM
rtr's Avatar
rtr
Car: 92 Z71
Engine: 350 TBI
Here's the deal - 92 full size pickup, 350, TBI. I'm on my 4th ignition module in about a year. This most recent one is only about a month old. What happens is, I get an intermittent no start condition. Strange thing is that the first few times it happens, I can crank and crank and crank, but if I just disconnect the module, and plug it back in, it starts right up. Eventually I get to the point where this no longer works, so I pop a new module in and I'm good to go. I know the unplugging and plugging in thing would seem like a bad connection, but I have checked all the wiring several time, even run a second ground just to be sure. Another ting is that the truck never dies once it is running and never misses a beat. It's just somethig with the initial startup.
Any ideas?
Old Oct 16, 2006 | 12:17 PM
silverta8702's Avatar
check and see what the alt is putting out if there is too many amps they will blow , i had the same problem , i just put in a select one modual ,there expensive but it never blew after that
Old Oct 16, 2006 | 01:21 PM
rtr's Avatar
rtr
Car: 92 Z71
Engine: 350 TBI
Yeah, I'll check that. Just seems wierd that I can unplug it and plug it back in and that gets it to start again. It's not a fluke either, it is repeatable probably 6 or 8 starts before it quits completely.
Old Aug 30, 2009 | 10:21 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Re: Repeated Ignition Module Failure ???
How about do you run a second ground for the ignition module? I'm having some pains with mine and am looking for help.
InfernalVortex
Apr 20, 2021 11:31 AM
RS Reaper
Oct 17, 2018 07:52 PM
Fanatic1074
Oct 2, 2015 03:47 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
