testing injector wires on TPI
Old Oct 19, 2006 | 07:59 AM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
Transmission: 700 R4
Hey
anyone know how to use a wattage tester and see the amount of volts coming off of the injector wires on a TPI? I know how to test the injectors, i just didnt know if you can test the wire and about what the amps should be coming out when running of course.
Old May 1, 2011 | 09:14 AM
numerobis1982's Avatar
Car: 91 Sonoma 4wd w/tpi swap
Re: testing injector wires on TPI
You can measure the coil resistance of the injector to see if any are bad, connect an ohm meter between the two connectors on the injector, they should read between 13 and 16 ohms if the are good. If they check out good you can get them professionally cleaned and have a nice set of injectors
http://www.youtube.com/watch?v=_g8PdrT0MCU
1992rs/ss
Jan 31, 2025 05:10 PM
jklein337
Sep 19, 2018 06:23 PM
Jae992
Aug 27, 2015 09:07 AM
Brcharrelson
Aug 26, 2015 07:47 PM
Sanjay
Aug 12, 2015 03:41 PM
