A/C Woes
Old Nov 8, 2006 | 07:40 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
A/C Woes
My 85 IROC-Z blower fan only blows air out the top dash defroster vents. Switching the control to A/C max, bi-level, heater does nothing. Any ideas on what and where to check? Thanks, Badman
Old Nov 8, 2006 | 08:33 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Broken vac. line. Look on intake manifold for hard thin vac line. It will be the broken one
Old Nov 9, 2006 | 06:03 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Default when a vac problem arises. This is a common thirdgen problem. A search will provide a ton of info.
JamesC
Old Nov 9, 2006 | 03:07 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
What search words would suggest. I find all kinds of engine vacumn leak info but none a/c blower specific. Thanks, Badman
Old Nov 9, 2006 | 03:10 PM
FlaTToPP75's Avatar
Car: 92 Camaro RS 25th Anniversary
Engine: 305 TBI
Transmission: 5 speed
If the main vac line in engine compartment is ok also inspect the vac lines to the vent selector control on the back side of the control head i ran into an issue where the diaphram was leaking on mine.
Old Nov 9, 2006 | 03:20 PM
JamesC's Avatar
Try "defrost and vent". FlaT's suggestion is a good one.
JamesC
Old Nov 9, 2006 | 03:57 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Thanks fellows, i'll try those things. Thanks< Badman
Old Nov 22, 2006 | 06:17 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
A/C Woes Fixed
My problem turned out to be the vacumn divirter valve located on the a/c controler in the dash. It was broken and causing a vacumn leak.Found one at the Chevy dealer and replaced it. Now I control where I want air blowing out of. Badman
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
