BIG problem car misfiring
Old Nov 23, 2006 | 05:03 PM
TigerZ's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
i went to replace my clutch a few days ago but only got about halfway done and didnt feel comfortable doing it so i put it all back together.
i was told to remove the distributor cap and wires because removing the tranny removes rear force of the engine and it tils forward causing the distributor to hit the firewall.
i removed both the cap and wires and put it back together as perfect as i could get it. i have checked my wiring 1000 times and its right. when i start the car it mises terribly and makes a popping sounds after about 5 seconds. just now i started it up and let it run for about 15 seconds and fire burst out of the throttle body.
wtf happened???
i have a guy comming tomorrow to look at the car and another on monday. i need help asap.
thanks guys.
Old Nov 26, 2006 | 04:27 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
It sounds as though the firing order is still screwed up. Also check the rotor for damage as well as inside the cap. Get #1 plug up on the compression stroke & pull the dist cap - the rotor will be pointing to #1. Wire the cap with the proper firing order & direction from there.
Post back if you still have problems.
Corky
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
