New alternator shot?
Old Nov 25, 2006 | 07:38 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I put a new alternator on my car but set up under the car and its not charging the battery. The car also dies when I disconnect the battery. I get no power out of the main stud when running but do get power out of the harness clip. I noticed that the clamp on the wire I connected to the stud was almost touching the housing. May have arced, shorted out, and fried the regulator? The alternator shaft is magnetized when running too.
Old Nov 26, 2006 | 04:15 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
From what you describe, it sounds like the alt is not charging. To validate, take the alt out & have it tested. I really haven't seen a wire arc to ground unless it touched ground. Check around the stud for a burn mark.
Corky
Old Nov 26, 2006 | 04:49 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
It looked like it was touching, but obviously wasnt or the wire would be fried and the battery would have been dead when I went to start it. I cant think of any other reason. The battery was pretty dead when I put the alternator on and started it a while back, and a tag that came with it said not to do that, but I ignored it. Maybe that fried it.
Old Nov 26, 2006 | 05:04 PM
84transam78239's Avatar
Car: 1989 Firebird formula 350
Engine: L98 long tube headers BBK TB
Axle/Gears: 3.73 positrac
check your alternator fuse, we had the same problem on my freinds GTA, he thought it was a bad alternator but it was actually a bad fuse, it should be on the inside fuse block under the dash by your pedals
Old Nov 28, 2006 | 04:11 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Well I checked for power right at the source so I doubt thats it, but it could be blown anyway, I'll check it.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
