alternator won't charge until rev engine
Old Dec 5, 2006 | 04:48 PM
djtricia's Avatar
Car: 1986 Z-28
My alternator doesn't start charging until I rev the engine over 2500rpm. Then it's fine most of the time. If I shut it off and it sits for awhile the same thing happens. I've checked all the connections to make sure they are clean. I'm thinking it's a diode going bad. Does the charging circuit go thru the gage in the dash?
Old Dec 5, 2006 | 05:18 PM
BadAssNovas.com's Avatar
Car: 74 Nova
Engine: 383
Transmission: TH350
Do you have a 1-wire alternator?
Old Dec 5, 2006 | 09:46 PM
djtricia's Avatar
Car: 1986 Z-28
Ther is one wire connected to the back of the alternator that has 12 volts. There is also a wire at the same location with a plug that plugs into the side (top) of the alternator.
Old Dec 5, 2006 | 10:43 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
wrong pulley size maybe? The realationship between the alternator pulley and the crank pulley should be about 3:1 for the street. The alternator is probably headed out. I would just get a new one with a lifetime warranty. They can be had for about $130.00 with exchange for a 124 amp model at motor supply. thats what I recently did. That fixed my under charging alternator.
Old Dec 6, 2006 | 01:49 AM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
I had a similar issue Mine was just my pos gauge. I put the amp clamp on the alt, and it worked fine. Read 45 amps at idle. Put a volt meter on the bat, 14.2 volts at idle. gauge said 11ish. revved the car, volt meter worked fine. I later put a new cluster in it and it read correctly. The old one made friends with the trash can.
Old Dec 6, 2006 | 08:23 AM
djtricia's Avatar
Car: 1986 Z-28
I'm thinking it's the gage too.
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
