Removing needle from speedometer
Old Dec 18, 2006 | 02:36 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Is there a sure fire way to remove the needle from the speedometer? I need to fix/replace the odometer / trip meter and I need to remove the needle first. All of the ones I've found at the junk without the needle were broken off. IE: the pin the needle mates with were snapped off. Any help would be appreciated.
Old Dec 18, 2006 | 05:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You shouldn't need to take the needle off to get the odometer apart.
Old Dec 18, 2006 | 09:54 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Well I have one without a needle and I need to take the faceplate off to get to odometer. Is the center hole large enough to slide over and around the needle? If so then no problem.
Old Dec 19, 2006 | 05:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Aperion is correct. Check the following link for repair:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
TrevinE
Sep 14, 2015 03:20 PM
Stroopwafel
Sep 11, 2015 06:38 AM
andy74
Sep 3, 2015 08:41 AM
