Best alarm for my third gen
Old Dec 20, 2006 | 03:04 AM
outlawracer's Avatar
Car: 82 camaro berlinetta/87 sport coupe
Engine: 87 LG4 305
Transmission: world 5speed
hey guys i have a 1982 berlinetta. my car keeps getting broke into and egged and i really need the best alarm i can get. im looking for a $400/600 range. can you all help. thanks guys
Old Dec 20, 2006 | 05:05 AM
AUSSIROC's Avatar
Car: 1999 subaru forester GT (urgh)
Engine: ej20 turbo
Transmission: 5speed
Axle/Gears: 4.11:1 awd
Hey,
I just got an alarm/immobilizer fitted today that i'm pretty happy with.
Mine has the following features that might suit you too: dual stage shock sensor (with adjustable sensitivity), glass breakage sensor, allpoints of entry alarms, 3 point immoboliser (fuel pump, ignition, and prom i think), auto rearm, keyless entry, battery backup, and flashing led light. You can get other that sense body heat in the car and stuff too.
I'm in Australia, so you might not be able to get the brand i used (Rhino).
Good luck with it!
Old Dec 20, 2006 | 01:02 PM
Engine: 87 LG4 305
Originally Posted by AUSSIROC
Hey,
Good luck with it!
witch system did you go with, i found the web site on it but theres a lot of diffrent systems
Old Dec 20, 2006 | 01:56 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I went with the AutoPage, p/n RF-420LCD. it can do much as you want or as little. It all depends on which add-ons you want to buy.
Old Dec 20, 2006 | 06:12 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
I went with the Viper 791XV
http://www.directed.com/security/vip..._responder.asp
Old Dec 20, 2006 | 08:41 PM
AUSSIROC's Avatar
Engine: ej20 turbo
I went with the "RA". The two piece alarm / immoboliser unit.
BTW, can you park your car elsewhere? You probably can't (obvious solution), but just out of interest, does it get broken into at work or home, etc?
Old Dec 20, 2006 | 09:58 PM
Engine: 87 LG4 305
home
Old Dec 21, 2006 | 07:08 AM
AUSSIROC's Avatar
Engine: ej20 turbo
home
Bummer. Not much you can do about that then, huh. Good luck with it all!
Old Dec 21, 2006 | 02:27 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
alarm is not going to stop eggs, i think i would try a camera or at least a motion sensor. my alarm is two way it will page the key fob when the alarm is set off.
Old Dec 21, 2006 | 06:22 PM
Engine: 87 LG4 305
i know it wont but if its egged i would like to know when it happend. you never know if you in the right place in the right time you mite chach them in the ack
Old Dec 21, 2006 | 07:36 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I have a Clifford system. Base package includes just about everything (2 stage shock, vehicle immobilizer, 2 stage proximity sensor, door lock/unlock, and hatch release). It also has a pretty wicked anti-car jacking feature. You can opt up for remote start and window control.
Base package was $400 installed
Old Dec 21, 2006 | 09:04 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
get a kill switch, kill switch, kill switch. it will stop most of them from stealing your car. saved my car!
Hotrodboba400
Dec 10, 2019 07:07 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Stryker412
Sep 7, 2015 09:11 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
