crazy coolant temp tpi HELP!!
Old Dec 26, 2006 | 06:51 PM
chris051240's Avatar
at cold start engine runs for approx 5-15secs and dies on 87 tpi. checked the "9th" injector on pass side with noid, light comes and and car wont run at all until plugged back in. upon further inspection noticed on mt2500 scanner that start up temp was at 200 F and air temp was only 38 f. Obviously cts not reading correctly. perform test, remove connector and watch scanner. temp changes but not to full hot. then jumper yellow to black at cts and should be -40 f but only drops to 114 f. I checked all power and ground at ecu and ck for short to ground and resistance on both the yellow and black wires and no prob found . cts is reading all different numbers but not the value that they should be. ofcourse no ses light either, it does come on and go out at key so assuming its working correctly and before unplugging sensor no codes present. POSSIBLE ECU FAILURE? I cant figure the darn thing out.
Old Dec 26, 2006 | 07:37 PM
brians88gta's Avatar
Car: 88 gta
Engine: 350 HSR
Axle/Gears: 3:27 borg warner 9 bolt
i had that problem wouldnt start or if it did it run like crap ended up bein the coolant temp sensor for the computer and it didnt throw a code either
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 26, 2015 04:59 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Sanjay
Aug 12, 2015 03:41 PM
