How do you change the front signal bulbs?
Old Dec 29, 2006 | 01:01 PM
al_44's Avatar
Car: 88 Camaro
Engine: 305 5.0 litre TBI
Ive been searching the boards and i cant find any info on what the best manner to change the front turn signal light bulbs is. Any info would be greatly appreciated.thanks
Old Dec 29, 2006 | 03:34 PM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
Axle/Gears: limited slip disc
If I remember correctly you go from under the car, turn the socket counter clockwise, and pull the socket and bulb out the back of the housing. I'll have to look at my car when I get home to be sure though.
Will
Old Dec 29, 2006 | 06:55 PM
al_44's Avatar
Car: 88 Camaro
Thanks, i switched out my right one with a new one but it still doesnt work. Also now ive noticed that while driving my right turn signal in the dash stays on. (Not flashing just solid) Any ideas of what could be causing this problem?
Old Dec 29, 2006 | 08:21 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
Sounds like a burned out bulb (not necessarily on the front) could be any of the bulbs. One bulb buring out can make the lighting system act strange.
Old Dec 29, 2006 | 10:04 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I have one like that too. All the bulbs light and function properly, but the instrument panel indicator for the right blinker lights and stays lit as long as the lights are on. I haven't investigated yet, but have a feeling there is a minor short in the right front.
Old Dec 29, 2006 | 10:26 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
When my left turn light stayed on solid, it was because my front left turn signal bulb was burned out. The bulb has 2 filaments in it, so even though it lights up when the lights are on it won't flash. At least that's how it was for me. I sure GM along with most car companies have similar schemes to let you know when the turn signals aren't functioning correctly.
Old Dec 30, 2006 | 10:52 AM
Al Hasse's Avatar
Thanks, not to sound rude, but I know about how the lights work, and am, for the most part, familiar with the circuit. What I tried to say was ALL the exterior lights and blinkers work normally (no lights or blinkers are burned out). When I turn on my lights, the indicator in the instrument panel for the right turn signal comes on and stays on (not real bright, but very noticeable). I figure it's the right front because it's the only one associated with lights - as in park lights.
69 Six Pack
Oct 5, 2015 07:51 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
