Code 43 problem
Old Jan 10, 2007 | 09:37 AM
ls2twntur1200hp's Avatar
Car: 1988 Firebird Formula
Engine: 5.2 tpi
Transmission: th700r4- TCI
Axle/Gears: fourth gen rear 3.42
Code 43 problem
I have an annoying problem. Everytime i start the engine i wait 5 seconds and then- Presto- the service engine light. The circut to the knock sensor is fine, the knock sensor is new. So what the **** is wrong! I think but havent checked, because i dont want to fork out 80 bucks for it- that the distibuter module is bad and isn't advancing the timeing enough for the check. PLEASE HELP!BEFORE I LIGHT THIS THING ON FIRE!
Old Jan 10, 2007 | 10:14 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
no, don't burn it, tell me where your at & i'll come take it off your hands for free to save you the cost of a match & fuel
this may help, open them in windows picture & fax viewer so you can zoom in to read them, you may need to save them to your computer to do it.
Attached Thumbnails Code 43 problem-43.gif   Code 43 problem-43b.gif   Code 43 problem-43c.gif
Old Jan 10, 2007 | 10:53 PM
Engine: 5.2 tpi
Thanks for the help but the only problem is i have a direct feed knock sensor-speed density tpi, so i dont have an esc-i did but retrofited, i'm pretty sure that has somthing to do with it. As far as i can tell my wiring is good but i read a continous 4.88 volts at the ecm and at the knock sensor. See why i'm so confused.
Old Jan 10, 2007 | 11:49 PM
DENN_SHAH's Avatar
at 4.88 volts it will kick the code, it should pull down to around 2.5 volts key on engine off.
the sensor may not have a good ground, did you put any sealer on the knock sensor such as teflon tape?
here are the diagrams for a 92 TPI SD system.
Attached Thumbnails Code 43 problem-43d.gif   Code 43 problem-43e.gif   Code 43 problem-43f.gif
Old Jan 11, 2007 | 08:11 AM
Engine: 5.2 tpi
Thanks for the diagrams, i dont have a service manual for the 90-92 engine so those diagrams really help. When i get home i'll check the resistance in the knock sensor to see if its good. Which it better because i dont want to have coolant sprayed in my face when i change it
Old Jan 12, 2007 | 08:24 AM
Engine: 5.2 tpi
I checked my knock sensor for resistance and got nothing, then i checked the old one and got nothing, i took the positive lead and stuck it on the connection and stuck the negative on the treads. Am i doing that right and the new knock sensor is bad or what, either way i ordered a new knock sensor.
Old Jan 12, 2007 | 07:52 PM
DENN_SHAH's Avatar
sounds like the sensor is bad.
they are very fragile, dropping them on a hard surface can damage them.
they can also be damaged when you put them in.
i really hate using the nut on the side the connector goes on, a little too much torque on the wrench & the sensor gets trashed.
Old Jan 12, 2007 | 11:52 PM
Engine: 5.2 tpi
ya it was the sensor, I think i over torqued it, but it was covered on the warranty so its all good. Thanks for the help.
Old Jan 13, 2007 | 12:08 AM
DENN_SHAH's Avatar
no problem
chazman
Aug 28, 2018 03:25 PM
db057
Sep 4, 2015 07:57 AM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
