inconsistent stalling/starting problem
Old Jan 14, 2007 | 11:28 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
every once in a WHILE in my 89' formula 350 TPI, the car will stall, then when i go to start it, it will not turn over at all, it will just click. or other times it will just not turn over when i go to start it up period (not following a stall).
1) could this be a bad ignition module?
2) if so, why does it only happen once every few months???
3) when i try it a few hours later, it always works fine, why!?!?!
(ignition module is the only thing in the car i havent touched since i bought it. the car currently has 260,000+ miles)
(i have the summit pro-torque mini starter, installed it about a year and a half ago)
THANKS!
Old Jan 14, 2007 | 11:42 PM
Burntz's Avatar
Car: 1986 Trans Am
Engine: Mild 10:1 355.
Axle/Gears: 9 bolt
THANKS!
Sounds like a starter to me, but those ignition modules are tricky. Just pull it and take it to O' Reillys to test it (for free)
All you have to do is take the dist. cap off and pull it
Old Jan 15, 2007 | 12:10 AM
bigchief's Avatar
oh wait no i think i meant where you put the key in, is it the key solenoid?? sorry....
the entire distriubuter is brand new, no way anything in there is broken already....
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
