gotta be a way !!!
Old Jan 15, 2007 | 04:13 PM
truegmman's Avatar
Car: 86 Iroc Z/89 Firebird Formula
Engine: 355/305tpi
gotta be a way !!!
Is there a way to find out the ohms of your vats system with out the old keys , bought a 89 formula that the owner had lost the keys...dealer tells me car is to old and they cant pull up the origanal vats value.got to be an easier way to do this without buying all the reistors to make up the values of all 15 keys .....any help i am losing my hair on this one
Old Jan 15, 2007 | 04:35 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
If you don't have the key how are you going to turn the ignition switch?
Old Jan 15, 2007 | 08:37 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
truegmman, try another dealer, other wise, its resistor trying time.
ringo234, a new VATS lock cylinder comes with a key without the VATS pellet in it, its only use is to cut a new key that has the right pellet in it.
Old Jan 15, 2007 | 08:57 PM
truegmman's Avatar
Engine: 355/305tpi
I will try another dealer and hope that will work before I try the reistor trick. Didnt know if there were certain values gm used for certain car lines or threw in what ever they wanted out of the 15 values
Old Jan 16, 2007 | 12:49 AM
DENN_SHAH's Avatar
you could have any of the 15 possible combinations, here is a list of them,
https://www.thirdgen.org/vats_passkey_system
good luck
Old Jan 17, 2007 | 11:42 AM
Firebat's Avatar
Have a key made without VATS. Buy a bunch(or 15) of resistors (or buy a variable resistor also known as a potentiometer, but you'll need an ohmmeter/multimeter to measure the resistance) from Radio Shack and hook them up like you would for VATS delete. Should be able to hunt down the correct value that way.
un4givin89
Nov 4, 2001 12:22 PM
Jim85IROC
Car Audio
Jul 19, 2001 05:26 PM
hookin88formula
Jun 9, 2001 10:46 PM
RoadRocket L98
Mar 20, 2001 08:02 PM
The ODB
Carburetors
Feb 1, 2001 03:29 PM
