gauges go haywire when lights turned on
Old Jan 23, 2007 | 08:34 AM
titan20's Avatar
Hello everyone. I'm new to this forum -- just purchased an '87 IROC with the 350 TPI. My problem is kind of strange. At night, when I turn the lights on, the tach and oil pressure gauge both quit working and the right signal marker lights up on the dash. During the day, the voltage reads low on the gauge, and sometimes the volt gauge just starts bouncing around and going crazy. Only the right side of the gauge cluster seems to be affected. Do I alternator problems or is there a wire grounding out somewhere in the gauges? I does any voltage checks yet -- the car had a new battery installed at the dealership where I bought the car and a new belt (smog pump is bypassed).
Old Jan 25, 2007 | 06:36 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Sound like you should be chasing grounds. You probable have a bad one somewhere. Good luck there I have seen a ground in the trunk of a mopar make the radio go nuts
Old Jan 25, 2007 | 11:11 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i agree with bilms01, look behind the instrument panel on the left hand side of the steering cloumn bracket for the ground. if you have a book, its called the G200 ground.
on the "right signal marker lights up on the dash", if your talking about the turn signal indicator, look for a ground problem, a bad connection, or a bad bulb at the right front turn signal.
Old Jan 26, 2007 | 07:35 AM
titan20's Avatar
Thanks for all of the information. I'll have to dive into the wiring and try to sort the problem out.
Old Aug 16, 2008 | 08:18 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: gauges go haywire when lights turned on
ever find a solution to your problem?
Old Aug 17, 2008 | 04:09 PM
sparkyew's Avatar
Anymore info on this problem. My problem sounds very similar. None of my gauges are working anymore(only the mechanical speedo). The gauge fuse in blown under the dash and blows soon as its replaced. My voltage gauge use to bounce around before everything quit. And when I turn my headlights on the headlight alarm or something constantly beeps. I pulled my gauge cluster out. Everything visually looks ok. I guess my next step is to measure the resistance across each gauge on its own.
Old Aug 13, 2012 | 08:45 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Just found this older post and thought i would add to it. If you have the right side of your cluster going funky, I've found the printed circuit on the back of the instrument panel had a crack or break in the copper print. All I did was put a drop of solder on the break to complete the circuit again. This is also a good time to clean up the connectors and replace the bulbs, and clean the ground connection.
Ghettobird52
Jul 5, 2024 11:18 PM
Derick15
Sep 17, 2016 05:28 PM
Fronzizzle
Aug 17, 2015 02:52 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
