Fuse keeps blowing
Old Jan 28, 2007 | 04:43 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Fuse keeps blowing
I keep blowing the same fuse. Dome/hatch/cigarette/mirror lites/locks has been blowing since I got my car back from body/paint shop. Any idea what it might be? It will work for a while and then blow. Can it be a ground somewhere. They did have door panels off at one point as well as the fenders.
Old Jan 28, 2007 | 05:05 PM
dave-92gta's Avatar
Car: 92 trans am/ 93 dodge spirit V6
Engine: L98 V8 - 350
Transmission: TH-700-R4
grounded wire is my guess. my fog lights do this, its really anoying. i will throw another 20A fuse in my fog lights and then they will blow if i hit a bump
Old Jan 28, 2007 | 05:16 PM
Axle/Gears: Posi
Is there a way to search this out and find which wire?
Old Jan 28, 2007 | 06:35 PM
dave-92gta's Avatar
i tryed to fix my fog lights in the summer, but it was way to hard. i know nothing about wires or diagrams. maybe give people on there more information, when does it blow, what do you do to make it blow? its hard to tell you what to do if when im in canada haha. next time you drive your car, pay attention to these sorts of details. the next step could be to take off the door panel and start looking for loose wires or wires that might be pulled and plugged back in
Old Jan 28, 2007 | 10:12 PM
chevhedz28's Avatar
Car: '89 formula,'88 Iroc
Engine: 350,305
sounds more to me like a loose or broken power wire than a ground. check the back of the cigarette lighter and see if the wires are still attached to it. if not I'd start checking all of the other accessories you had mentioned one of them has to be causing the problem.
Old Jan 29, 2007 | 12:04 AM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Wiring diagrams at autozone.com
click "Vehicle Repair Guides"
tell em your car, then
"Chassis Electrical"
then choose the diagrams for your year. You'll be able to trace the entire circuit with that.
A meter helps a lot.
Old Jan 29, 2007 | 12:13 AM
Axle/Gears: Posi
I have a meter. I really can't tell what the conditions are that make it blow. I put a new one in tonight so tomorrow I will try to pinpoint what the conditions are and repost here.
Old Jan 31, 2007 | 07:17 PM
Bad-Newz's Avatar
Car: '88 Camaro / '91 Camaro RS
Engine: 3.1L MPFI V6 / 3.1 MPFI V6
Transmission: 700R4 / 700R4
Axle/Gears: ??? / 3.23's
I havethe same problem as you do. But now it has spilled over to thefuse controlling my gauges aswell. The 20AMP use o blow when ever I would go over a bump. But then it suddenly stopped. However, the other day, i was driving and just happened 2 fiddle with the cigarette lighter and...POP.. It blew. The other fuse doesnt even last 5mins. after puttin it back it.... trust me its a pain in a--...
Old Feb 1, 2007 | 08:06 AM
Axle/Gears: Posi
Well I put in a 20amp and took out my cigarette lighter and the fuse has not blown in the last few days. So on my next "work on the car in the garage" day I am pulling the lighter socket to check for loose wires because when summer comes I need to use the phone charger.
Old Feb 2, 2007 | 07:41 AM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Make sure there is absolutely nothing inside the socket-- anything metallic will blow the fuse everytime.
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
90formulaVortec
Sep 3, 2015 09:26 AM
