Turn Signal Level
Old Feb 2, 2007 | 03:31 PM
MavViper's Avatar
Turn Signal Level
I'm having an issue with not only my high beams but also my turn signlal indicators. My turn signals will just light up, they won't blink off and on. Also with my high beams, as I posted before, the high beams on the passenger side don't light up at all, in fact when I switch to high beams the passenger side lights turn off completely.
I'm wondering if it has somehting to do with my turn signal level. If it was bad at all, would it cause those problems?
Old Feb 2, 2007 | 03:57 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
more than likely not. If the t/s light the lever is doin it's job. Check to make sure you don't have bulbs or possibly bad sockets (ft and Rear) most likely problem is a bad T/S flasher
The check the wiring connector you might have a broken wire there on the Pass side
The T/S and headlamp dimmer switches are two separate switches
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
skeltor
Feb 2, 2016 10:37 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Randomtask2
Sep 7, 2015 05:06 PM
