where to wire O2 sensor heater circuit
Old Feb 3, 2007 | 03:42 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I am trying to figure out the best place to wire in my O2 sensor heater. I had it wired into the pink circuit that used to supply power to the gauges and AIR solenoids because the AIR system isnt there anymore. That resulted in a blown fuse however.
So where would the best place be to wire in the O2 heater?
Thanks for any help and experience.
Old Feb 3, 2007 | 03:49 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Any 12V+ with key on will work.
I wired mine into the power wire for the knock sensor module. The heater shouldn't draw much power; are you sure it was wired up correctly.
Old Feb 3, 2007 | 03:58 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
yes -- I just had one too many things on that circuit including the ignition box.
I understand that any switched 12 volt source WOULD do but which one has the most overhead? I guess I am just looking for someone to say "I wired mine in here, and its been working great"
Thanks.
Old Feb 3, 2007 | 04:02 PM
Lo-tec's Avatar
It worked great!!
Old Feb 3, 2007 | 04:05 PM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
sorry kinda off subject where you able to get a heated O2 sensor? thanks Daniel
Old Feb 3, 2007 | 04:08 PM
Lo-tec's Avatar
No, I was not able to get a heated O2 sensor.
Old Feb 3, 2007 | 04:36 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Ha Ha. Ok sorry I hadent really considered the Knock Sensor module power but I was hoping to just wire into the fuse block.
And if you search for AFS-74 that should give you a list of places that sell heated O2 sensors that fit our cars. then you just have to wire it up....
Old Feb 5, 2007 | 03:07 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Well, I spliced off of my fuel pump circuit post-relay to run mine. That way the sensor doesn't sit and use juice while my key is in run but the motor isn't running.
From what I've read, heating the sensor without the engine running can lead to premature failure. That article was wideband specific, though.
Old Feb 5, 2007 | 04:33 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
well I just wired it the way I had it before -- using the 2 leads for the AIR select and divert solenoids. Except this time I moved my ignition system from that circuit to the bat terminals on the fuse block with a switch in the loop so I can turn the ignition on and off independently of the key. its seems to be working well so far.
$750 L98
Feb 1, 2025 02:25 PM
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
