does anybody have the VATS schematics for a 92?
Old Jan 22, 2007 | 08:57 PM
griff305's Avatar
My VATS is a disaster and i need the schematics so i can wire it properly
Old Jan 22, 2007 | 10:37 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
https://www.thirdgen.org/vats
https://www.thirdgen.org/vats_passkey_system
Old Jan 23, 2007 | 03:59 PM
griff305's Avatar
thanks. The previous owner didnt even have the module hooked up and the green loop was cut in it. What is the clear box with red and green led's??
Old Jan 23, 2007 | 07:08 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
As I understand it, if VATS is disabled on the chip (PROM), you dont need the module plugged in.
Old Jan 23, 2007 | 08:09 PM
griff305's Avatar
that may be true but it wont fire over so there is a wiring problem somewhere
Old Jan 23, 2007 | 08:58 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Im having the same problem right now...it was suggested to me to just bypass the starter enable relay, which is behind the drivers side kick panel.
Old Jan 23, 2007 | 09:13 PM
griff305's Avatar
or its supposed to be i have some huge wiring issues i appreciate the advice im get it done tommorow. Do you know what the clear box with red and grenn led's ni it is?
Old Jan 23, 2007 | 09:21 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Yeah, supposed to be....we had the kick panel off last week and didnt see anything like that
They suggested to me to bypass the starter enable relay, because I bought a new chip and had VATS disabled...they said that because I had VATS diabled on chip, than I may as well just unplug the VATS module, and bypass the starter enable relay.
VATS is disabled in my application, because I had to replace the ignition switch, and thought Id just pull all that out of the equation.
Old Jan 23, 2007 | 10:03 PM
griff305's Avatar
do you know what the clear box is with a red and green led in it is?
Old Jan 23, 2007 | 10:18 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Im sorry?
Where is this thing located?
Take a pic?
Might be aftermarket?
I dont recall ever seeing anything like that?
Old Jan 24, 2007 | 11:30 AM
griff305's Avatar
I think it is aftermarket. It is hanging under the steering column. Ill send u a pic of it tonight.
Old Jan 24, 2007 | 06:20 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
I have never seen anything like that..
Mine had some kinda aftermarket anti-theft system too, it was kinda like a plug that slipped into a little socket right next to the ALDL plug...I never knew what it did, and never seemed to have any effect...it was in the car when I bought it...
We removed it during this engine swap.
Old Feb 4, 2007 | 10:10 AM
griff305's Avatar
i jumped the starter enable relay and its cranking the motor. Injectors are pumping but the car still doesnt want to start
Old Feb 5, 2007 | 07:47 PM
lizardkng's Avatar
Car: 91 Z28
Axle/Gears: Stock
Alright, well, its out of my league now...
Check spark?
$750 L98
Feb 1, 2025 02:25 PM
RS Reaper
Oct 17, 2018 07:52 PM
thunder57
Nov 7, 2015 02:28 PM
AmorgetRS
Sep 28, 2015 09:33 PM
gta892000
Sep 16, 2015 12:37 AM
