Anybody Mount their MSD Box inside the center console?
Old Feb 4, 2007 | 05:01 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
I was thinking of mounting my MSD Digital 6 ignition box in the center console with a fan blowing air on it. Has anybody done this? From the looks of it I'm going to have to notch the plastic to get the box to fit properly. Any pictures would be appreciated.
Old Feb 5, 2007 | 05:52 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Anybody?
Old Feb 8, 2007 | 10:53 PM
Siggy's Avatar
Car: 1988 Camaro IROC LB9 F
Engine: 305 HO EFI
Transmission: TH700R4
Axle/Gears: GU5 LS 3.23
No never have...just wonder why. I looked at your photos and can understand you want a clean bay. I mounted a MSD under dash on a 29 A rod for that reason and I didn't care about the RF. Really you should keep the wiring short as possible, bear in mind that the MSD will generate a bit of RF and plastic is a poor shield.
Old Feb 10, 2007 | 09:06 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
I mounted mine on the old ecm bracket under the dash
Old Feb 11, 2007 | 11:13 AM
Cornholio7979's Avatar
Car: 89 Formula, 89 IROC
Engine: GMPP 350 HO, L98
Transmission: 4l60x2
Axle/Gears: not enough, good enough
Put mine inside the fender next to the battery. You can't see the box at all, and the wiring runs along side to battery wires, so you can't see that either.
Old Feb 11, 2007 | 05:54 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Speaking of RF does solid grounds at both the box and the coil help matters at all? I'd like to keep the box cool and as free from vibration as possible.
Old Feb 11, 2007 | 09:01 PM
Siggy's Avatar
Engine: 305 HO EFI
Absolutely....grounding is very important, I aways ground the case direct to bat-strap chassis lug with 14 gauge. The MSD can handle a fair degree of heat and vibration...they survive Hotrods which are quite firm. Dirt, moisture are to be avoided. Keep it vertically away from a heat source, some air movement over the case is desired, a fan only if confined and no other air movement available...inside the console box without venting would only contain the heat even with a fan, if you vent the console box you would most likely allow dust-dirt to enter past the trany. My 3G has its Crane 6Hi fitted to engine bay fender (clean bay was not necessary). The under dash sounds good but I would not place it close to ECM if its still there.
My Crane box sits just in front of the heater fan on fender in this photo.
http://Coolsiggy.smugmug.com/photos/117061496-M.jpg
Old Feb 14, 2007 | 07:17 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
What is "RF" You refering to "EMI" Electro magnetic interference?
Radio Interference?
Old Feb 18, 2007 | 01:01 AM
Siggy's Avatar
Engine: 305 HO EFI
Radio Interference?
Yes, Radio Freq or Radio noise normally comes with the high energy ignitions. If the car electronics work OK then your only other concern can be that expensive audio system or the neighbors tv.
Old Feb 18, 2007 | 01:10 AM
fast89ta's Avatar
Car: 85 Camaro Z28
Engine: 408 ci bbc
Axle/Gears: 10 bolt 4.11 ratio
I got mine on the dashboard right in front of the passanger, i like it there but some may not like looking at it if there cars an everyday driver.
Old Feb 19, 2007 | 08:57 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
Can I see some pics of the location next to the battery? My car has AC and I just can't find a place to mount it. Or how about pics of under the dash?
Thanks, mike
Old Feb 20, 2007 | 02:47 PM
fast89ta's Avatar
Car: 85 Camaro Z28
Engine: 408 ci bbc
Got a pic of mine on my cardomain, page 3. Link is in my sig.
Old Feb 20, 2007 | 07:02 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
here is where I mounted my MSD box. I doubt it will get to hot, I have dual fans blowing on it
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Firebird sweden
Aug 16, 2015 05:02 PM
midias
Aug 15, 2015 05:07 PM
