Auto Dimming Dome Light
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'd like to have auto dimming interior lights - the kind that ... after the door opens, the interior lights come on full, and stay on, until door is closed - when door closes, interior lights automatically dim or fade to off over time (like 20 seconds). Any ideas? Could rob a mechanism from another car and wire it in, but not sure what I'd be looking for exactly. Anyone ever seen an aftermarket job anywhere?
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
If you put a capacitor across the light bulb the capacitor will charge up while the light is on and when the voltage is removed it will discharge keeping the light lit until the cap slowly discharges to 0 volts. The time it takes to discharge depends on the RC time constant. I'm not sure of the value cap you will need. I'll try and find out at work on Monday.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
ADD A TIMER . . . . . . NOT AN ANVIL
The cap idea is impractical due to the fact the IR time
constant would require a cap WAY too large.
You should use a 555 type chip and an SCR.
With this tiny setup you can set the time
for any amount.
Happy Racing !
— If people drove any slower
they’d be going backwards —
Car: 87 GTA
How would this be built?
Car: 1990 Camaro RS
Engine: 305 TBI (LO3)
Axle/Gears: 3.08
For just a nice dimming not sudden ON.....OFF.... a capacitor would work nicely. The feature for 20 seconds after finally dim and shut off would require a 555 circuit. Basically a timer circuit and that's all I know. Lucky me Stephen, I'm headin off to become an electrical engineer this fall.
Car: 87 GTA
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
A capacitor with enough capacity to keep a light on that long would be VERY large.
There has got to be a better way. I'm in an ECE class right now, I'll do my best to figure one out
Car: 89 IROC Z28
Engine: 357 TPI
I checked it out at work and your right I would need about a 5Fd Cap. An engineer I work with is going to see what he can come up with.
Another option is to use a smaller cap and drain it through a resistor. You would then need an IC to take the voltage decay and mirror it to an output.
Im gonna do some google searches and see if I can find one.
I did some searching and found a guy that did what I described... Used an IC and a smaller cap to dim the bulb. Here is a diagram, should be able to build it with a few dollars at radio shack.
http://www.electronic-circuits-diagr...rsimages/3.gif
Car: 92 camaro rs
had a 86 camaro berlinetta that would do that if you had the headlights on and turned the car offthe exterior lights would turn off and the interior would come on and then fade out after you shut the door
my 85 has a timer for that.
It is very cool though, if you have the headlights on, and shut the car off, the headlights turn off and the interior lights come on. Then, they stay on for a minute after you shut the door, and then shut off. I may use this circuit so they fade out!
Car: 87 GTA
Sounds like we have a factory option, for something similar.
Any chance of figuring it out, and fitting it to other 3rd gens?
I'm not sure.
The lighting control is in a large "light module" located next to the computer. It controls everything, from blinkers to headlights to dash lights.
It has a pretty meaty wiring harness going to it as well.
I'm sure we could figure out how it works, but adding it to the stock harness would take some wiring.
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Try this circuit. To adjust the the brightness VR2 will adjust the initial brightness and VR1 will adjust the time to dim from full brightness to off.
The transistor used is a power transistor and will need a heat sink.
http://www.electronic-circuits-diagr...carsckt3.shtml
Car: 86 Z28
Axle/Gears: TBD
Car: 1992 RS
Engine: Carbed 350
Yeah - I googled the schematics for several - but I'm no electronics whiz - Solder and I don't get along! I was hoping I could just figure out what it was called, find a car make that had one, and go grab it at the boneyard or parts store.
Car: 1990 Camaro RS
Axle/Gears: 3.08
Basically all the new GM vehicles have them. I'm sure you could find one that's totalled but the problem I'd have is to find the actual module that does the dimming. That's the next hurdle.... for me anyways.
ambainb
Apr 25, 2016 09:21 PM
