What kind of Ignition setup is everyone running?
Old Feb 25, 2007 | 09:41 AM
HaIrLeSsHoBo's Avatar
Car: 86' Trans-Am (wrecked)
Engine: none currently
Transmission: Borg-Warner T-5
Axle/Gears: 2.86:1 w/ one broken axle
I am just curious to see what most people are running, probably some type of electronic setup if I had to guess. Anyways, I am running an old-style points ignition. I had to go with this instead of a simple electronic ignition because my intake gets in the way of the larger one with the built-in coil. So what does everyone else have?
Old Feb 28, 2007 | 02:13 AM
Siggy's Avatar
Car: 1988 Camaro IROC LB9 F
Engine: 305 HO EFI
Transmission: TH700R4
Axle/Gears: GU5 LS 3.23
If you are running points and carby then you must not be using an ECM computer, the ECM regulates the timing advance so a stock in-coil or the smaller external coil HEI wil not work. I would either keep it like it is or using a points trigger you can still use Crane or MSD multi spark analog ignition.
I use a Crane Hi6, it looks pretty, I later found out that I had gained zip.
Old Feb 28, 2007 | 09:44 AM
there are HEI distributors that have everything built in. all you have to do is connect a +12v wire to it, set the timing, connect vacuum advance, and that's it. there is no external coil or controller needed.
Old Feb 28, 2007 | 10:39 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
In my 84 I've got an MSD E-Curve distributor, an MSD 6AL, and a Blaster SS coil. The 88 is all stock HEI.
Old Feb 28, 2007 | 08:47 PM
MAC25DM's Avatar
Car: 1988 Firebird
Engine: 2.8 liters of fury.
Axle/Gears: Stock
I am running a MSD 6A ignition, MSD distributor, and ACCEL 8.8 MM wires.
Old Jun 30, 2007 | 08:57 AM
Re: What kind of Ignition setup is everyone running?
I was looking at the MSD 6A... what kind of a difference does it make for performance and cranking, if any?
Old Jun 30, 2007 | 12:35 PM
DIGGLER's Avatar
msd low profile distributor
msd crank trigger
msd programmable digital 7
msd hvc-2 coil
moroso 8.8 race wires
Old Jun 30, 2007 | 07:59 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
points is not electronic
points was before 1975
1975 and up was HEI
High Energy Ignition
large style in-cap
i think you guys are confusing things up here
if he cant fit a 75 and up HEI then he wont be able to use that red HEI one in the pic above either
he has some kind of clearance issue under the hood for some reason apparently
and why he called points an electronic ignition is beyond me
please elaborate
they do have kits to convert the old 74 and older points dizzies over the electronic, it includes a magnetic pickup and coil and such to replace the physical contact points pieces
hotrodders have been using these kits for decades
good luck
Old Jun 30, 2007 | 08:05 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
I am running a GM High performance distributor, Accel 300+ ignition box, Accel Brute Thunder super coil and Accel 8MM Super stock plug wires.
Old Jun 30, 2007 | 09:21 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
MSD 4 life!!!!!! LOL
MSD 6AL
MSD Pro-Billet distributor
MSD 8.5mm Wires
MSD Blaster SS Coil
MSD Adjustable Launch Control
what can i say?? i like MSD.. lucky i dont have a battery saver and/or a timing retard for nitrous(that i dont have/use)..
Old Jun 30, 2007 | 11:27 PM
1975 and up was HEI
large style in-cap
please elaborate
good luck
I never said I was running an electronic points setup.. I am running points, plain and simple, I just mentioned that I wanted to run the electronic but was unable to because the wider distributor hits my aluminum intake. I guess the intake was made before HEI and they just made sure that standard points distributors fit. I think that I am going to swap intakes soon so I can swap to an HEI. Is the performance increase of HEI over points worth the swap?
Old Jun 30, 2007 | 11:35 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
MSD ProBillet Dist. MSD 8.5 Wires MSD 6AL Ignition MSD Blaster2 Coil I have used Accel wires and cap and coil back when it was a 305 and the wires were junk. Dont waste your $ on them. Thats why every auto-parts retailer has them. MSD I have on the TA and the S10. They are great. Ive also run Taylor 8mms B4 on the TA and I wouldnt hesitate to run them again. IMO/experience the coil isnt a big deal of improvement until the upper RPM range. The ignition weather a MSD, Mallory or Crane is worth it. Distributors either a MSD or Mallory is top notch.
Old Jul 3, 2007 | 10:19 PM
plumminfool's Avatar
Car: 1988 camaro sport
Engine: 355
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
Started the process of changing from a stock HEI to a MSD pro billet distributor, Digital 6 box, and blaster 2 coil.
Old Jul 3, 2007 | 10:38 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
1984 Z28 with a 355,10.3 CR. and a NOS 150 shot. Still using the stock ign. system with Accel 300+ wires, NGK UR-5 shorty plugs gapped at .032". Shifts at 5700 rpm.
Auggie
Fast355
Dec 2, 2016 06:33 PM
db057
Aug 22, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
Street Lethal
Aug 13, 2015 08:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
