brake lights wont turn off
Old Feb 27, 2007 | 05:39 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
Axle/Gears: posi disc 3.23's
when i turn my car off the brake lights stay on. where should i look first for a short? is there a fuse for the back lights? i tried the one labeled 'tail' but that did nothing
Old Feb 27, 2007 | 11:27 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Check the switch that makes contact with the brake pedal. It is bad or out of adjustment. easy fix
Old Feb 28, 2007 | 01:00 PM
Zion's Avatar
Car: 1991 RS
Engine: 90' TPI 305
thanks SDIF, it was that. the little switch isnt broken, its the clip that holds it in place. can you get that at lordco?
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
