lost vats key
Old Mar 3, 2007 | 09:28 PM
twisted91's Avatar
Car: 1991 camaro
Engine: 355
Transmission: th350
lost vats key
i have a 91' camaro with a carbuerated 350 so the only thing the vats controls is the starter. my question is how can i bypass the vats, or wire the ignition switch to just start and turn off the car. i got a new lock cylinder without the vats wires. any help would be appreciated.
Old Mar 3, 2007 | 10:33 PM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
go give the vin to a local gm dealership and get a new key cut. it will be cheaper in the long run. btw you better get two keys cut with the luck youre having!
Old Aug 13, 2007 | 11:52 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
Transmission: Automatic
Axle/Gears: stock(what could be better!!)
Re: lost vats key
hey, pop off your drivers side kick panel, you will find a relay under some black sticky crap, there will be two really thick wires....cut them and splice the two together, dont worry about the relay side, just pit the two long parts together...those will bypass the the vats part of the starter relay...trust me, it really works, I actually JUST did this like half an hour ago.
Old Sep 30, 2007 | 12:58 AM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
Re: lost vats key
twisted, just checking on if you got your car going, im sure you did, but just wondering if the advice i gave was helpful at all?
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
3.8TransAM
Sep 27, 2015 08:37 PM
