Will a Delay Wiper Motor work with a non delay column?
Old Mar 18, 2007 | 08:00 PM
MNformula350's Avatar
My Formula currently has the delay wiper option, and I have a non tilt column out of my old 84 Firebird I want to put in, the 84 column has no delay wiper option, it just has high, low and off.
I really don't need the delay feature, because the only time I really need the wipers is to clean the windshield or if I get caught in a sudden rain.
I don't think that 88-92 cars had a no delay option, and I really can't use a 82-87 style motor as they have the pump mounted in the motor, with the washer bottle I have I need the external washer pump assembly like the 88-92 cars.
Anyway, will the wipers work if I use the 84's non delay column with the 90 delay wiper motor? Will the wiring even plug into the column?
Old Mar 18, 2007 | 08:21 PM
j dezzy's Avatar
Car: 87 TA
I tried that once before...didn't work...best would would probably to take the wiper arms off and swap 'em.
Old Mar 19, 2007 | 12:29 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Don't know for sure but was not the pump part of the wiper motor in 84???? If so then the 84 column wiring and switch probably won't work in your car. Also in 82 at least the wiring was different at the motor for a delay unit versus a non delay unit, as a different motor was used.
Have you considered swaping the switch and wiring from you current column to the 84 column???? This might be the best solution, thought I suspect it will take a little work to swap the switches and wiring.
Dave
Old Mar 19, 2007 | 09:10 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
put the 90 switch in the 84 column
good luck
Frozer!!!
Jan 19, 2024 04:55 PM
stalkier
Aug 13, 2015 12:59 PM
dhonda200
Aug 11, 2015 11:50 PM
slade5612
Aug 11, 2015 07:19 PM
1nastygta
Aug 8, 2015 07:38 PM
