Wiring Project...(pics inside)
Old Mar 22, 2007 | 02:34 PM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
This is in a 1990 firebird that used to have a v6 and now has a carbed 357/th350
Ok i have these pictures, i just need someone with a wiring manual to tell me what they are for.... here it goes....
2 brown spliced to 1 brown ..... orange & green w/ white spliced to green with white
cut off orange
orange and green and the other i cannot tell but it is on the same piece as the brake fulid sensor
i think this is for the AC? green/white & black
fusable link red/orange?
these were over on the passenger side tucked down by the header?
what sensor is that? and is that blue wire a stock color? or was that spliced on just happend to be blue? also is there another starter wire im missing?
Key on
key held (trying to start)
whats this fuse block for? under dash
Old Mar 22, 2007 | 02:36 PM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
Re: Wiring Project...(pics inside)
should this be connected to something? under dash
whiite spliced to yellow? drivers kick panel
two cut small yellows? dirvers kick panel
white spliced to baby blue under dash
Even if you could just tell me what ONE wire does, it will HELP ME TREMENDOUSLY!
THANKS A TON GUYS!!
Old Mar 22, 2007 | 02:53 PM
cool84's Avatar
Car: 84 trans am
Transmission: built 700r4
i belive that the fues block is for some of the curtesy items, and the warnig buzzer and stuff, try looking up ctsy fuse and what it does,
as far as the red wire you found down by the header that goes on the positive terminal of the starter, on my car theres like 3 wires that conmverge into the one connector for that.
Old Mar 22, 2007 | 02:56 PM
j dezzy's Avatar
Car: 87 TA
It's really hard to tell abotu a lot of those. most of these cars have been electrically molested over the years...I'll take a look at some of my diagrams and see if I can find anything for ya. If you want I've got a lot of diagrams that I can email you for your own reference.
Old Mar 22, 2007 | 03:06 PM
j dezzy's Avatar
Car: 87 TA
could the brown ones spliced together be a ground? have you tried tracing th ewiring and finding out where they go too? I think you're right about the green/white black wires. I think it might be from the A/C pressure switch.
Old Mar 22, 2007 | 03:11 PM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
wow guys, thanks sooo much for the help, this headache is getter a little better since i got some replies!
YES please send me any wiring diagrams that you have available, i will appreciate that so much!
my email is jeepsterxj@gmail.com
I am just trying to get this thing to start with the key! thats the biggest problem, and if i get that figured out, i will be happy since this car is almost strictly for the strip... i will go take some more detailed pictures today... my camera was being really lame and shooting horrible pics....
great, like i said each wire i get outta the way, is a step closer to starting it!
ill follow some more wires and see if i can located there connection!
also... that red wire (fusable link) does that go where the blue wire is? or the other post on the selenoid that has a small bolt?
Last edited by IceManRS305; Mar 22, 2007 at 03:13 PM. Reason: Automerged Doublepost
Old Mar 22, 2007 | 04:03 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Thats the plug for the power window/mirror/lock harness that runs into the doors. I only know that because I just put power windows in my car. Dont have to connect it to anything unless you add all that stuff later on.
Old Mar 22, 2007 | 05:58 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
If you need diagrams, you can find a ton on our ATGO Tech DB wiring page.
I'll be looking into my schematics as well. I'll let you know what I find.
Lou
Old Mar 22, 2007 | 06:18 PM
BigBadLou's Avatar
Engine: TPI
Check if the green/white happens to be the fuel pump relay wire. The orange might have been spliced into it as some kind of a hackjob.
The cut off orange wire is probably the second half of the orange wire from the splicing into green/white.
Is the green/white and black the same green/white that's spliced in the first picture?
It sure isn't for A/C.
Orange wire with fusible link goes on the big post on the starter. Once you connect it, a lot more things will suddenly have power in your car.
Blue wire goes to the knock sensor that's in the block, on the passenger side.
Hope this helps.
Lou
Old Mar 22, 2007 | 07:45 PM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
ok guys... all of your responses were greatly appreciated. i cant even thank you enough!
the problem actually was that the red wire wasnt on the starter! obvious to most, but not me lol... also i wasnt putting my foot on the brake... yea im an idiot lol...
any way the thing started cranking with the key... looks like the mystery was solved pretty easily thank the lord above! lol
im onto a new set of problems that i will to state in another section so i do not get off topic for this section....
Here is the the link if you guys want to follow along with the ups and downs of the rest of my project!
https://www.thirdgen.org/forums/engi...ml#post3274671have
Caspar
Jun 19, 2016 11:19 PM
gta90
Sep 15, 2015 04:00 PM
Bert87
Aug 23, 2015 03:50 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
