alternator not charging battery put in new alternator and new battery..still a prob.
Old Apr 5, 2007 | 03:50 PM
iiiluckyboyiii's Avatar
Car: 89 camaro rs
Engine: 305 tbi soon 78 lt1 400hp
ok i have a brand new battery and an alternator thats 2 months old.. i watch my cars voltage go down slowly until the whole car dies. I had autozone test the alternator and it was fine..i read on here that it might have something to do with my fan switch being bad wich it is but it has always been bad the fan is on when the car is on no matter what so ithe switch isn't even hooked to the fan. anyways. also my gauge lights have a dead short but they have been like that without the fuse in all winter..i have glow gauges so it doesn't matter. it has a cd player a dvd player and amp and subs but they have been it for about a year now also..with no problems.. i'm just confused as to what it could be if its not the battery or the alternator...nothing is on at all times its all off when the car is off.. so is there any one with any ideas?? cuz i'm out of them.. could it be the cable from the alternator?? if so man is there any way to bypass it and go strait to the battery man i dunno i'm just freaking out about this whole thing.. let me know guys thanks
Old Apr 5, 2007 | 03:57 PM
Car: 89 camaro rs
Re: alternator not charging battery put in new alternator and new battery..still a pr
delete one for some reason it went up twice maybe i'm a tard but i dont see a thing to delete one myself...
Old Apr 5, 2007 | 06:04 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
OK, I don't have an '89 manual, so I am looking at the '88 electrical diagram. There might be differences in '89 - perhaps someone else can fill in the blanks. Looking at the electrical diagram, you need to make sure the 20A C/H Fan fuse is good - that feeds the "F" terminal on the connector. The "S" terminal comes from a fusible link off the starter & the "L" terminal goes to the idiot light.
If this is your configuration, you should have 12v at the "S" terminal all the time & 12v at the "F" terminal KOEO. With the engine running, measure voltage on the large red wire at the back of alt - if you have battery voltage, 12.x then the alt is not charging. With everything working properly, you should have 13.x + volts at that terminal. Check a few things out and post back - we'll get you back charging, it's not a complex system.
Corky
Old Apr 5, 2007 | 06:48 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
It isn't the best picture but it is out of my 89 Firebird. Hope it helps.
Attached Thumbnails alternator not charging battery put in new alternator and new battery..still a prob.-firebird-charging.gif
Old Apr 5, 2007 | 09:18 PM
Car: 89 camaro rs
all right guys thanks i'm going to try some things and get back to you tomorrow .
Old Apr 6, 2007 | 12:58 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
make sure both red wires on the alt are hot
if not then they need to be connected so that they are
i always loop the spade red wire down to the the charging post with the charging wire
if they are hot then something else is wrong somewhere, inside the alt, or something else
good luck
Old Apr 6, 2007 | 09:34 PM
Car: 89 camaro rs
well i looped the wire and presto it worked, the strange part is the wire going to it is fine i did a test on it and it was good but whatever thanks a lot guys you helped a lot
Old Sep 7, 2012 | 06:47 PM
xavier_pr84's Avatar
what do you mean that you looped the wire im having this same exact issue the altenators not charging my battery at all altenator and battery are good i got them checked at autozone last night
Old Sep 22, 2012 | 11:37 AM
mojo_jojoe4's Avatar
Car: 1991 Firebird Vert
Engine: 383 L98/LT-1
good luck
I'd like to know this as well, since my car is having the same issue.
Old Mar 22, 2013 | 11:03 AM
tilaink's Avatar
ditto getting frustrated
Old Apr 20, 2013 | 06:30 PM
jaybdaboat's Avatar
Car: 1987 Sports coupe/z28
Engine: 2.8/ swapping 5.3
Axle/Gears: Open 3.42
Meant plug a wire to the back of the alt connect it to the battery.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
Dialed_In
Aug 20, 2015 01:45 PM
