help with 1984 Z-28 wiring
Old Apr 8, 2007 | 11:07 PM
1welder's Avatar
I need some help figuring out some wiring on a 1984 Camaro that was originally the 5.0 HO. The guy I got it from really butcherd it up. I have most of it figured out but cant find the wiring to three parts. I am not sure which wire goes to the fan temp switch. I found one that plugs in, but it is piggybacked thru the same loom as the air con and temp sending unit. It has a black wire and large black plug. That puts it on the wrong side of the motor from what the little manual I have says ( the manual for the HO 350 conversion). Second, on the radiator there is a switch that I believe is for low coolant, cant find any thing close. Last, I cannot find the wires for the alternator! Plugs are still on the original alternator, but for the life of me I cannot find where they are cut. So far, I can only find three wire that are cut and they are blue, dark green, and brown. Any help would be great, and if anyone has a good picture of a stock engine bay, that would help immensely. I used the stuff in the sticky that Vader posted and while helpful, I still got questions. Thanks. Oh, I'm putting a 305 back in it as thats what I have in case this helps.
1Welder
Old Apr 9, 2007 | 10:46 AM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Re: help with 1984 Z-28 wiring
I remember my dark green was on the driver-side head near the front of the car. It travels with the AC wiring I believe. This is a coolant temp/fan switch. Only one wire to sensor.
I only have one wire from alternator to harness, and I can't think of the color at the moment. The other connector was jumped with a small wire to the alternator output. Self-exciting in a way, I guess.
Is it light blue, dark blue, or just blue?
I've got the haynes manual at home, I'll try to update my response later.
Old Apr 9, 2007 | 11:22 AM
1welder's Avatar
The blue wire is basicly blue, not light or too dark. The green wire for the temp switch for the gauge is there and I have it identified, I guess the other black wire that is in that same loom that has the right plug is probably the right one for the fan temp switch, but doesnt seem right as this switch is supposed to be in the right head on the other side of the motor. I think I might have the alternator figured out. Just hate to get a manual for a couple stupid wires. Thanks.
colton_carlson
Mar 8, 2019 12:21 PM
Cleotiz
Jan 6, 2018 08:56 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
suzuki949
Aug 28, 2015 08:07 AM
Exxon Limited
Aug 9, 2015 08:13 PM
