Ignition Issue!
Old Apr 11, 2007 | 03:16 PM
Monster Zero's Avatar
Car: 1991 Camaro Z28
Ignition Issue!
Ok enough is enough!
My 91 Z28 (LB9) has been giving me problems for a while now. It's a series of problems that I've been fixing since the previous owner neglected them horribly. With out giving a long sob story and the cars entire history, here's the problem:
The runs/drives for a while till it gets hot, than begins to idle rough and will stall, often times unable to start again. I know I have a vacuum leak via the EGR which I am in the process of replacing however, the EGR I don't think is the problem in this case. Someone suggested it may be a fuel pump, but if it is why doesn't it do it all the time? Is the fuel pump capable of overheating? My friend suggested it may be the ignition control module. I need help before I go tearing either area of the car apart to look. And yes I do get an SES light on usually before it stalls. Please Help!
Chris
Old Apr 11, 2007 | 06:53 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: Ignition Issue!
well what's the code that is set when the light comes on? that would be the first thing I would look at.
Old Apr 11, 2007 | 07:48 PM
Re: Ignition Issue!
no idea, I don't have a tech 1 tool
Old Apr 11, 2007 | 09:25 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: Ignition Issue!
Autozone will read the codes for free.
Infested
May 22, 2018 11:56 PM
WIzmo
Aug 30, 2015 02:30 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
