how to over ride vats on 92 camaro rs
Car: 92 camaro rs
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 2.77
i have a 92 camaro rs 305 tbi i recently changed the complete wireing harness now the car doesnt do anything if you turn the key the engine doesnt even crank people told me that it can be the vats i just want to try to override the vats i need the car running asap
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: how to over ride vats on 92 camaro rs
Are you sure it's VATS? Did you check the voltage on the purple wire on the starter solenoid? If you don't see 12V on with the ignition turned all the way to Start, then it "might" be VATS or it might be still some wiring problem.
I actually posted some steps on what wires to check between the ignition cylinder and starter to see where the 12V flow is interrupted. If you do a search on VATS and starter, you'll find it.
Hope this helps.
Lou
Hope this helps.
Lou
Car: 92 camaro rs
Engine: 305 tbi
Axle/Gears: 2.77
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Linson
Aug 21, 2015 02:12 PM
