Coi + wire has 14 volts at idle, why???
Old Apr 24, 2007 | 11:50 AM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Axle/Gears: 9 bolt 3.91
Coil + wire has 14 volts at idle, why???
I recently installed an MSD 8920 and I powered it through the original coil positive wire. I'd like to know why the coil positive wire would have 14 volts running at idle. I'm pretty sure this fried the 8920, but the MSD guys don't think so, and they repaired it for free.
I'm guessing the original owner used a wire he wasn't supposed too for the coil positive.
When I had a stock hei setup I never had any trouble running the coil off this wire.
ONe more question, why when I turn the key on, I can hear a high pitched noise coming out of the alternator, other than that it works fine, I never noticed it in my last thirdgen, and I used the same alternator?
It's not that loud.
Old Apr 24, 2007 | 12:02 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Re: Coi + wire has 14 volts at idle, why???
Ummm, your entire electrical system typically runs at about 14 volts while the alternator is turning. I have a feeling the MSD guys are right.
Old Apr 24, 2007 | 03:04 PM
Rayvan's Avatar
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
[quote=tompumped;3316430]I recently installed an MSD 8920 and I powered it through the original coil positive wire. I'd like to know why the coil positive wire would have 14 volts running at idle. quote]
It takes 13.8 just to charge a car battery. 14 isn't out of line.
Old Apr 24, 2007 | 03:16 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
14 = normal
Old Apr 24, 2007 | 07:13 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
I didn't think the voltage should be that high for some reason. thanks
Old Apr 24, 2007 | 07:14 PM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Everyone else is right, mines the same thing. If it bothers you that much you could always get a lower amperage alternator
Old Apr 24, 2007 | 10:15 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
also, the high pitched whine is normal too. It is the internal regulator of the alternator. How loud it is varies from car to car, and for different alternators.
Old Apr 25, 2007 | 05:28 AM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Never said it bothered me, I just thought it would be lower at idle.
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
