91' Z28 Blowing AC Fuses !!!! Help !!!
Old May 6, 2007 | 02:14 AM
texasgomer's Avatar
Car: 91' Chevy Z28 (white)
Engine: 355 TPI
I replaced the resistor the blower motor and checked all of the wiring from the compressor and blower. I'm stumped. I put a 25amp circuit breaker in place of the blown fuse and the blower runs great until I move the control to Max or Norm AC and when the compressor kicks on within a few minutes the blower shuts off. Can anybody help me ??? I replaced the ac control panel thinking it might be the controls but, it wasn't. What next ??? Could it be a ground problem ???
Old May 6, 2007 | 06:43 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: 91' Z28 Blowing AC Fuses !!!! Help !!!
One easy thing to check would be to pull the connector on the A/C clutch and try if you still blow the fuse. If not, it's most likely a bad clutch.
Lou
Old May 6, 2007 | 11:38 PM
texasgomer's Avatar
Engine: 355 TPI
Thanks Lou ... I will check it out !! Hope things are well in my home town of Austin, TX. I appreciate your input. Brent Walker
MM2Robinson
Oct 1, 2017 09:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
timonator
Sep 10, 2015 07:55 PM
64goatman
Sep 9, 2015 01:09 PM
90formulaVortec
Sep 3, 2015 09:26 AM
