No power, please help...
Old May 25, 2007 | 05:24 PM
alclark74's Avatar
I'm having a problem with my 92 camaro. The battery is fine, I've tested power to the ECM and im getting continuous power there, but the is no power to the fuse block. I actually had it started and running for a day by popping the clutch, but then when I put the key in to start it it doesn't do anything. The key in ignition warning doesn't even work, headlights int lights, nothing works, tried popping the clutch again and nothing.
PLEASE anybody help point me inn the right direction or have any ideas..
Thank you, Al
Old May 29, 2007 | 08:18 AM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
Re: No power, please help...
if i were you i would simply disconnect the battery positive terminal and re connect it that should do it i dont know why but that fixed it for me
Old May 29, 2007 | 04:46 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Check fuse links (down by the starter) and that you have power to the ignition switch.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
