fuse help please
Old May 27, 2007 | 06:51 PM
j88l98irocz's Avatar
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
fuse help please
1988 iroc tpi Every time I turn on the headlights the lamp fuse blows and I have no instrument cluster lights I recently installed a pioneer stereo could this have some thing to do with the fuse blowing also when the fuse blows the stereo blinks off but then comes back on when the car is running.
Old May 28, 2007 | 07:23 AM
Transmission: t56
Re: fuse help please
anyone have any Ideas?
Old May 28, 2007 | 11:08 AM
Niko the french's Avatar
Car: Camaro'89 TPI
Engine: 305 Ci
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Sorry for the answer i click so fast.
What is the size of your fuse?
You can test with another size if you have a 15A you can test with a 20A
Last edited by Niko the french; May 28, 2007 at 11:13 AM. Reason: Automerged Doublepost
Old May 29, 2007 | 03:03 PM
Transmission: t56
it is the 10 amp lamp fuse
Old May 29, 2007 | 03:56 PM
Car: Camaro'89 TPI
Engine: 305 Ci
And if you test with a 15A Is it the same result ?
Old May 29, 2007 | 04:37 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
10A is 120W. A fuse blowing quickly indicates that the current draw is at least 4 times as large. The stereo blinking also indicates a very large draw (short circuit). It is not a good idea to up the fuse rating, unless you want to see where it smokes.. It's quite likely that a recent stereo installation is the culprit. I have seen many very bad wiring jobs, and is amazed that no more cars catch fire than does.. Stereos are often connected to the instrument lighting circuit, check that connection.
Old May 29, 2007 | 05:26 PM
Car: Camaro'89 TPI
Engine: 305 Ci
I know that but he says he have a new stereo so it's possible this new stereo wants a little more power ( and i don't say test with a 30A just with another size like 15A )
And it's possible it's a bad wiring but he says "but then comes back on when the car is running" so check the permanent live ( i don't know if it's a good term ) and the non-permanent live on your wiring and effectly i think you can see a difference
Old May 30, 2007 | 10:54 PM
Transmission: t56
SOME ONE B4 ME HACKED THE STOCK HARNESS I RAN ALL NEW SPEAKER WIRES AND FOUND THE YELLOW WIRE FOR IGNITION POWER BUT I CANT SEEM TO FIND THE CONSTANT POWER WIRE. DOES IT MAKE A DIFFERENDE THAT I USED 14 GUAGE WIRE FOR THE SPEAKERS? ALSO I DISCONNECTED BOTH POWER WIRES TO THE STEREO AND TURNED ON THE HEAD LIGHTS AND THE FUSE STILL BLOWS IM CONFUSED.
Old Jun 1, 2007 | 08:29 AM
Transmission: t56
could I have a bad ground?
Old Jun 1, 2007 | 10:33 AM
BA92GTA's Avatar
Regardless of who did the installation, a few other things are sticking out in my mind.
  • Always wire a high-power requirement stereos and amps directly to the battery "postive". Never use the existing power supply and ground source.
  • The speaker wire gauge required will be detailed from by the manufacture of the speakers, showing impedance and polarity.
  • The ground for your new system needs to be to firewall of the car. And the body needs to be grounded.
Stereo installations can cause all kinds of havoc on newer cars, I did an installation on a car with an On Star System, which upon attempting to remove the stereo I learned could have deployed the air bag. And most definitely contacts On Star upon being disconnected.
My advice is to take the right approach, with the old stereo out cover the disconnected wires and connector. Use a separate power supply "postive", and "filtered" ground, then one from the fuse panel; install a fuse link in line from the battery, to your equipment yourself rated for what you are pulling, in amps, to the new equipment.
As for the headlight fuse blowing, it seems that you have a dead short in your headlight circut.
With the stereo disconnected and none of the wires going to ground you can discount this as the problem, and shouldn't be blowing fuses. The only lead in the stereo system that even remotely works with the lights on you car is for the panel light at the stereo. It functions with the dimmer switch.
Troubleshoot the head light circut first, correct fuse no fraid or broken wires going to ground. This goes for the running lights, head lights, fog, and the taillights also. For the record my 92 fog lights cause a me a lot of headachs. Once resolved, the reinstall the stereo as described above.
Lmao @ FullSizeWagons ~SMOKE TEST~ comment..... Too Funny....
Always use new parts it will save you money in the long run.
Old Jun 2, 2007 | 07:07 AM
Transmission: t56
thanks alot man!
Old Jun 2, 2007 | 10:21 AM
Transmission: t56
I figured it out. It was the ground
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
AmorgetRS
Sep 28, 2015 09:33 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
