One touch power windows
Old Jul 7, 2007 | 07:13 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
I've gotten a little spoiled driving my wife's 06 Chevy truck with the one touch power down windows. Wondering if anyone has done this mod and if so is there a relay to wire in or should I get window motors out of a Chevy truck?
Old Jul 9, 2007 | 12:46 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: One touch power windows
Nah, too much work..
It is however possible to do. In addition to the switch, it only requires one relay, two diodes, and one end limit switch (with a self fabb'ed bracked). Double this for a one touch up function too.
If you want to do w/o the end limit switch, you'll have to make a current sensing circuit instead. I suspect this is how it's done in production cars but I have no info on it
Old Jul 9, 2007 | 01:10 PM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
i wish there was a nice simple way to do it... I too am used to it. Mainly because my truck (88' Chevy) the window button i would just press and it would get stuck... So go all the way down then when it got down it would kick off... Same with the way back up.
Old Jul 9, 2007 | 01:24 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
The Window / up / down / vent module for my alarm adds that feature....
Raf
Old Jul 9, 2007 | 10:46 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
My alarm has the same feature, however, if the ground or power to that module goes bad, the windows will not work. Happened once or twice when working under the dash an knocked connection loose...
Old Jul 9, 2007 | 11:40 PM
Kwik89GTA's Avatar
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
Use the express down module from a 4th gen. Heres the diagram for a 1995.
Later, Kevin
Old Jul 9, 2007 | 11:44 PM
Tobashadow's Avatar
that would be very very easy to wire in if you can find one.
Old Jul 10, 2007 | 12:53 AM
Stephen's Avatar
Car: 87 GTA
You could always hit up a stealership. But, I dont see why Autozone orsomething, would have them.
Old Jul 10, 2007 | 09:57 AM
85_ZED28's Avatar
Car: '85 Z28
There is! Google or ebay search DEI 530T. Its a current sensing unit. I installed this in my car a couple years ago, works perfect. Auto up and down on both windows. Install is a breeze, especially with our window switches in the centre console instead of the doors.
edit: Heres the thread on TGO with the wiring diagram you'll need for installation:
CLICK
if the link doesn't work just search for DEI 530T on here and its the first topic
Old Jul 10, 2007 | 04:55 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
So you completed the install in the console itself?
JamesC
Old Jul 11, 2007 | 12:39 AM
Tobashadow's Avatar
looking at the diagram the other night everything you need is right there in the console.
It's nothing more then tie in before and after the switch's.
Old Jul 12, 2007 | 02:04 PM
85_ZED28's Avatar
Car: '85 Z28
JamesC
Yep
Old Jul 12, 2007 | 03:16 PM
JamesC's Avatar
Where did you place the module itself, at the rear, front, or side of the shifter? Any problems or is installation straightforward? Advice?
JamesC
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
