Speedometer problem
Old Jul 8, 2007 | 10:13 PM
Dolfan348454999's Avatar
Car: 92 z28
Transmission: auto
Speedometer problem
I have a 92 z 28. Recently the speedo has been acting weird. It isn't totally broken it just seems to work when it wants to. Occasionaly it drops to zero for a second of two then works again, or sometimes it just doesn't work for the whole drive. The odometer also has been completely broken for a while. I'm guessing it is just a bad connection of some sort. Should I just start looking through the wires? I tried searching bur havent seen a post were the gauge works most of the time.
Old Jul 10, 2007 | 10:34 AM
Car: 92 z28
Transmission: auto
Re: Speedometer problem
anybody know anything
Old Jul 10, 2007 | 10:50 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Intermittent speedo function can be caused by loose connection at the vss on the trans tail housing. Make sure that connection is secure and that the wiring hasnt become frayed, or the insulation skinned off which may cause circuit grounding. If the connection is loose (at the vss), try a zip tie to keep it tight. Hopefully, the vss isnt on it's way out..
Another troublesome area is where the pigtail plugs into the back of the speedo. This connection sometimes come loose or gets jarred if work has been done under the column area. If the first suggestion doesnt help, check the connection at the back of the speedo.
Good luck
Old Jul 10, 2007 | 07:28 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
The speedo on my 91 bird does the same thing pretty frequently. I've found that a good WHACK with the back of my hand between the speedo and tach immediately fixes the problem for the rest of the day (it usually does this in the morning after it's been sitting all night). I know I need to replace the speedo, but it's not real high on my priority list.
Old Jul 11, 2007 | 06:03 PM
Car: 92 z28
Transmission: auto
thnx for the help
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
