3rd break light
Old Jul 17, 2007 | 03:38 PM
OneWheelWonder's Avatar
3rd break light
I have a third brake light on my back windshield in my 92 RS. But it doesnt work. Ive already checked the bulb, and it appears to be fine. The wiring that goes into the light looks fine as well. Any ideas on why it wont work? thanks in advance
Old Jul 17, 2007 | 03:54 PM
Stephen's Avatar
Car: 87 GTA
Re: 3rd break light
Does the 3rd brake light wire get voltage, with the hatcj closed? Open, it won't. You would hafta check the contacts on the bottom, at the very rear of the trunk, for voltage.
Old Jul 17, 2007 | 09:02 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: 3rd break light
He should have the light mounted on the top side of the rear glass (inside), should have 12V whenever the brake is pressed, even with the hatch open - there are no contacts at the rear of the hatch. Sometimes the reflector gets brittle from the heat of the bulb and the contacts don't touch the bulb anymore. I'd go out and check mine, but it's out being serviced...
I've replaced my assembly due to a broken reflector with one from http://www.custom-leds.com/ and haven't had a problem since.
eightsixseven
Dec 16, 2024 01:50 PM
jaridjohn
Jul 8, 2024 03:49 PM
89fast5oh
Aug 24, 2015 08:14 AM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
