Trouble finding the flasher on an IROC-Z
Old Jul 17, 2007 | 09:47 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
My girlfriend's turn signals are acting up really wierd, they'll flash real fast and then real slow at random times. So i went and bought a new flasher to put in, but I can't find where it goes!
The Haynes manual says it's either behind the fuse box towards the firewall, or under the center console. I looked in the fuse box compartment and didn't find it, so I'm assuming I have to take apart the whole center consule to put in this stupid $5 part? Am I crazy or do I just not see it?
Old Jul 17, 2007 | 10:20 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Re: Trouble finding the flasher on an IROC-Z
You could try to turn on the Ign. sw. and then flip on the turn sig., crawl under the dash and listen for the click. Mine was above the fuse box on the dr. side.
Auggie
Old Feb 14, 2009 | 08:09 PM
TA-Rocks's Avatar
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
Mine is over the brake pedal and above the relay panel. Its built into the top of the panel. It has a silver can and and a flasher relay also some fuses. pull the black plastic clips together and the front will drop to access it
Old Feb 14, 2009 | 09:09 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Mine was right on the corner of my dash and my center console under that black panel.
Trickskier
Jul 25, 2017 08:39 PM
Bstrang6
Sep 8, 2015 04:29 PM
PestilenceIV
Sep 5, 2015 04:37 PM
g.l.mos
Aug 22, 2015 12:02 AM
