need help with gear selector switch
Old Jul 29, 2007 | 04:33 AM
pawcio's Avatar
Car: GTA 89
Transmission: TH700
Axle/Gears: BW 9 bolt
Hello
I have a funny problem with gear selector switch in my 89 Formula with th700r4.
Switch not working when is mounted in proper location (shifter of course) If i took out the whole thing and grab it in hand it works reassembly to shifter and again not working.
I tried another gear selector switch from my friend's car and results are identical
please help
Old Jul 29, 2007 | 10:24 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: need help with gear selector switch
I guess it is possible that the switch is not being mounted in the right spot. The holes on the switch bracket are sloted for adjustment.
( A Guess !! )
Maybe the shifter is bent where the P/N switch mounts to it. That might be enough to cause the plastic arm on the switch to make poor/no contact with the little metal contacts inside the thing.
( That's just a "shot in the dark " )
Old Jul 30, 2007 | 10:54 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Another shot in the dark: could be the wires as well. Once you put the shifter in place, they are bent differently than when the shifter is out. It could make a big difference.
Lou
Old Aug 2, 2007 | 03:23 PM
pawcio's Avatar
Car: GTA 89
Transmission: TH700
thanks for shooting ;-)
I know about the holes but he is not working at any position...but I'll check shifter contact with switch.
eightsixseven
Dec 16, 2024 01:50 PM
junkcltr
Aug 2, 2019 11:12 PM
Dialed_In
Aug 20, 2015 01:45 PM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
