Turn Signals weird
Car: 91 Camaro RS
Engine: 305 TBI
Turn Signals weird
Alright
this is on my 91 rs
my right front turnsignal in the front bumper doesn't work.... the light comes on with the lights but won't flash... and also my right turn signal bulb indicator in my dash stays dimly lit when the lights are on.... but comes off and on normally when it's flashing
then my left front bumper light is just alot dimmer than the right
ideas on where to start narrowing stuff down....
i'm thinking bad grounds.... and now i think i should prolly check the fuses
but any other ideas??
-Ryan
this is on my 91 rs
-Ryan
Car: 1986 Iroc-Z
Engine: 5.0 Tune port
Axle/Gears: Stock? 2.73
Re: Turn Signals weird
check your connector that comes out of your steering column and connects under the dash. mine was all jacked up due to previous owners replacing the multi function switch in a hurry. your plastic connector may be bad, if it is then do what you have to do. id stay away from soldering and use heat shrink tubing instead.
