Am I right.
Old Aug 23, 2007 | 05:03 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Am I right.
If i try to start my car, but it doesnt even turn over, then i retry and it will turn over and start, it could be my starter solinoid?
Old Aug 23, 2007 | 05:09 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Re: Am I right.
Yes. Could be.
Old Aug 23, 2007 | 05:53 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
Re: Am I right.
could be starter selinoid bad connection somewhere VATS clutch safety switch neutral safetly switch pass key starter relay fusable link lots of funny little things...dead battery
Old Aug 23, 2007 | 05:56 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: Am I right.
well if i try to start it and it doesnt, I can get it jump started and it will start right up. It seems like i gave it big charge to start it or something. Thats why i thought it was the solenoid. well also i have the little chip on the key off. I took off the resistor on it
Old Aug 23, 2007 | 07:12 PM
Stephen's Avatar
Car: 87 GTA
Re: Am I right.
Wait....You took the chip OFF the key? Without the chip, the ECM disables starting.
Old Aug 23, 2007 | 07:36 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: Am I right.
No. You can bypass the little chip thing on your key. It has worked for months now without it.
Old Aug 23, 2007 | 07:50 PM
Stephen's Avatar
Car: 87 GTA
Re: Am I right.
Yes, you can bypass it. My 89 is bypassed. But there was no mention of it being bypassed, just that it was removed.
I've seen people get standard spares made for a VATS car, then wonder why it won't start.
Old Aug 23, 2007 | 08:13 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: Am I right.
Lol well its bypassed. sorry anyhew. Ya i think its my starter solenoid.
Old Aug 24, 2007 | 12:09 AM
Beast407's Avatar
Re: Am I right.
Poor battery/ground connections.
Old Aug 24, 2007 | 12:51 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: Am I right.
I read full power when try to start it. It just doesnt turn sometimes. extremely weird
Old Aug 24, 2007 | 01:55 AM
Red92Bird's Avatar
Car: '92 firebird
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 10 bolt 3.42 gears with eaton posi
Re: Am I right.
i agree with beast. check your battery connections and make sure they are not corroded or loose. physically grab a hold of them and move them around. ive had a few cars that acted like they were dead and fired right up after playing with the battery cables
Old Aug 24, 2007 | 10:11 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: Am I right.
Just because the battery shows proper voltage doesn't mean it has enough amps to start. Since you can jump it and it starts would tell me to check the battery/connections. Have the battery properly load tested.
Old Aug 24, 2007 | 10:34 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Am I right.
Well, you need to troubleshoot it a little more to find out what's causing your no-start.
What exactly happens when you turn the key to start and it doesn't? Do you hear a click from the starter solenoid? Does your voltage gauge drop a little? Do you hear any sounds at all? Do your lights dim (yes, try starting with your lights on)? Does anything happen if you hold the key longer? Does it crank if you try to start repeatedly (like every second)?
Lots of questions, I know, but the answers will help you find out what it is.
Lou
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Quzyle
Oct 15, 2015 03:35 PM
Logan Bryant
Sep 23, 2015 06:51 AM
Racerx974
Sep 19, 2015 10:16 AM
