Voltate jumping to max then back over and over.
Old Aug 26, 2007 | 03:01 AM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
Like the title says.
Sometimes it does and sometimes it doesn't.
My voltage will jump and max out (18) then back to 13ish - where it normally is. It jumps quickly over and over, making my headlights flash.
What does it sound like to you guys?
Voltage regulator?
Just a bad ground?
Old Oct 29, 2007 | 03:56 PM
Car: 86 Firebird
Engine: 2.8 V6
Re: Voltate jumping to max then back over and over.
Just trying again. The problem is still occuring, but now I'm starting to notice that I can actually feel it a little bit in the driving when it does start jumping back and forth.
So, anyone?
And are our voltage regulators built into the alternator?
Old Oct 29, 2007 | 06:33 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
yes they are.
They are easy enough to replace. Replace the bearings while you are there.
Old Nov 2, 2007 | 03:35 PM
racerd146's Avatar
Car: 92 firebird
deff sounds like you alt is going if it was a bad ground you would get lower voltage
Old Nov 3, 2007 | 02:15 PM
Car: 86 Firebird
Engine: 2.8 V6
Thanks for the replies.
We actually pulled out the reciept on the alternator and it has a lifetime warranty so I just got back from returning my voltage regulator.
I was kinda excited about taking it apart, but oh well, I saved $17
Old Nov 17, 2007 | 12:28 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
So it was your alternator?? Mine jumps to 18 my lights get bright then it will fall back to normal it does it alot, kinda annoying to looks like im flashing my brights at someone.
Old Nov 17, 2007 | 10:43 AM
Car: 86 Firebird
Engine: 2.8 V6
Yeah. Thats what mine were doing. My headunit would even turn itself off sometimes because the voltage got so high.
We replaced the alternator with the lifetime warranty on it and I haven't had any problems since.
Since our voltage regulators are built in, you're taking out two possibilities at once.
Old Nov 17, 2007 | 02:49 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Well ima have to get me a alternator then lol, dont wana cook my cd player and subs ^^ or my ecm
Infested
May 22, 2018 11:56 PM
Derick15
Sep 17, 2016 05:28 PM
86IROC112
Aug 17, 2015 02:00 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
