what happened to my car
Old Aug 27, 2007 | 10:01 PM
Grizzlybear226's Avatar
Car: 1988 Trans am
Engine: 358
i went out today to finish cleaning my 88 trans am to get it on the road and realized that my gauges don't light up when i turn the lights on, also my tail lights don't come on when i put the lights on either.the brake lights work fine and so do the blinkers, i have no idea why its doing this. i recently tried replaceing my drivers side headlight motor with a reman. one and it doesen't work, but it did before, could i have done something to the electronics and shorted out the system doing that?please help
Old Aug 27, 2007 | 11:31 PM
KCGTA's Avatar
Car: 1989 GTA
Engine: 5.7 L L98
Axle/Gears: 2.77
Re: what happened to my car
You may have. Have you checked the fuses? If you aren't lucky and it isn't that, it's wire check time. I blew a fuse once in a 1983 T/A, taillights were dead as well as cluster lights, but headlights worked fine. Hopefully that's what it is.
Old Aug 27, 2007 | 11:55 PM
Car: 1988 Trans am
Engine: 358
thanks alot, i'll check them tomorrow and see how they look.hopefully thats all i'll need.
Old Aug 31, 2007 | 12:36 AM
Car: 1988 Trans am
Engine: 358
i replaced my fuses and everything works fine now
Old Aug 31, 2007 | 12:49 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Remember, fuses usually pop for a reason... So be on the lookout for the culprit.
Old Sep 1, 2007 | 10:45 PM
KCGTA's Avatar
Car: 1989 GTA
Engine: 5.7 L L98
Axle/Gears: 2.77
I'm glad it was that easy! Toehead is correct, usually fuses do blow for a reason, but in the case of my 1983, it did not happen again. If your fuse blows again (deamons? power surge?), I would look at that headlight motor you replaced first. If it never happens again, rock on!
jhawkeye
May 25, 2022 06:33 PM
Wade787b
Sep 29, 2015 01:15 PM
mustangman65_79
Sep 1, 2015 03:51 PM
jharrison5
Aug 19, 2015 05:53 PM
