Voltage too low, alternator is healthy
Old Sep 3, 2007 | 05:43 AM
Cornholio7979's Avatar
Car: 89 Formula, 89 IROC
Engine: GMPP 350 HO, L98
Transmission: 4l60x2
Axle/Gears: not enough, good enough
Just picked up an 89 IROC a week ago, and have been going through basic maintenance. The voltage is at 13.5 to 9 when the car runs. It's kinda random, but it doesn't vary quickly.
I had the charging system tested at a parts store, and the alternator charged outside of the car. When in the car was tested, the charging system was a bit too low, 11 something. So I thought it might be a bad diode in the alternator. The alternator passed in all tests on the machine. The car doesn't have any aftermarket parts, still has the original radio.
The car's voltage seems too low, even though I haven't noticed the lights dim at all. I'm used to my firebird's voltage running at a constant over 13 with 2 amps, 2 12's and 4 aftermarket speakers running with A/C and all the lights on without dimming on an autolite OEM replacement alternator. Is it normal for the voltometer to vary so much or do i have a deeper problem?
Forgot to mention that the battery also checked out healthy, and I've been able to drive it to work and school with lights and A/C without any problems.
Old Sep 3, 2007 | 08:03 AM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Re: Voltage too low, alternator is healthy
Where are you seeing the voltage sag, the in dash gauge or by using a meter? It should not go to 9 volts while running. With a charged battery it would take a heck of a load to drop your battery voltage that low.
off car alternator tests are just a little short of worthless, I would encourage you to test voltage in the car when you are seeing the sag. Check at the alternator terminal and the battery. Be sure to check for bad connections.
Old Sep 3, 2007 | 11:00 PM
92camaroz28ss's Avatar
Car: 92 z28
Engine: fast burn 385
Transmission: t56
dot know if this is helpful or not,but in my car, a 92 z, my alternator was constantly putting out low volts and it was because of a connection issue at the bottom of he column - apparently the regulator is controlled by those wires, at least thats the only thing i could come up with
Old Sep 6, 2007 | 11:46 PM
what column?
Old Sep 7, 2007 | 09:25 PM
Car: 92 z28
Transmission: t56
the steering column
Old Sep 8, 2007 | 12:30 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
I agree check the voltage with a multimeter at the battery - first static(engine off)then with the car running but with nothing on.Static test should be at least 12.5VDC and running 12.8VDC to 13.4VDC.Only time you would see 9VDC would be during starting.You could still have a bad diode under load.Or it could be as simple as a loose connection,a battery cable breaking down(due to age).An aging belt,or tensioner,could be slipping but you would also notice cooling issues.
Old Sep 9, 2007 | 06:53 AM
I've gotta check the wires then, cause the belt is fraying a bit but not slipping. I'm broke for now, so the belt is a later fix. No way my dash voltometer is just retarded or cross-eyed, right?
If it were breaking down, it would be at the ends, right? It wouldn't be corroded or messed up in the middle of the line unless the shielding were frayed,I think.
Old Sep 9, 2007 | 08:53 AM
coolram62's Avatar
Engine: LU5 305 CFI
Cables can break down at any point but the ends are the most common.Heat and other underhood conditions are harsh on the wire harness in general.And then if you haven't replaced them yourself there's the factor of age.Resistance builds up in wires as they age(big factor for spark plug wires).
If the belt is fraying then you are not far from being left on the side of the road.Also if it's fraying then more than likely it's stretched.
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
RyanJB
Sep 2, 2015 01:27 PM
