Quick question about hatch switch on bird...
Old Sep 11, 2007 | 02:31 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I have a quick question that I have not been able to find an answer to. I have an 87 Trans Am and like all our lovely thirdgens, it has the electric hatch lock. Ofcourse, to open the hatch, I just push the button on my dash. I recently bought a remote start/remote door unlock kit which I installed successfully. The kit also has a channel 2/aux setting for trunk release. This is my problem. There is only one wire to use from the remote module. That one wire is negatively charged (meaning it controls the ground circuit). From what I understand, the hatch switch is positively triggered. Since there are 4 wires on the back of the hatch button. 2 I'm guessing for the lighting, and the other two for the switch itself. What do I need to do (which relay to use) to make this work...? If its even possible. I might have tested the wrong wires (forgot the colors) but it seemed that both the button-activated wires were positively charged. I bought a relay, but I don't think its the right one. It has 5 "prongs": 1 for ground, 1 for 12volt, 1 for switch means, and 2 for lights. Would I be able to use this? Thank you
Old Sep 12, 2007 | 04:27 AM
HCR13's Avatar
Car: 1987 Trans Am
Re: Quick question about hatch switch on bird...
bump
Old Sep 12, 2007 | 07:11 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
You should be able to use any relay.
You will set it up as follows: (if you are correct and the switch needs a 12 volt signal)
Wire one side of the coil to +12v.
Connect the common to the supply side of the switch (one of the non-lighting wires)
Connect the NO prong to the hatch release (the other wire)
connect the other side of the coil to your remote wire.
There you go.
You can actually wire it in parallel so that the switch still works as well.
Old Sep 12, 2007 | 10:01 PM
HCR13's Avatar
Car: 1987 Trans Am
ok, so with the current relay I have now:
to the 12volt prong, I add 12volts
and I'm not following where everything else goes...
Old Sep 15, 2007 | 01:25 AM
HCR13's Avatar
Car: 1987 Trans Am
pretty much I need to know how to convert a ground (-) signal into a 12v(+) signal. The relay I have is this one http://cgi.ebay.com/12V-20-30-AMP-RE...QQcmdZViewItem
Old Sep 16, 2007 | 03:35 PM
Toehead's Avatar
Would a wiring diagram be helpful?
Old Sep 16, 2007 | 05:29 PM
HCR13's Avatar
Car: 1987 Trans Am
yes please! !
Old Sep 16, 2007 | 08:44 PM
Toehead's Avatar
OK, doing some homework now (Electrical engineering for Mechanical majors ironically enough)
Ill bust one out when I get done.
You said that the switch has 2 wires,,, one is +12 and the switch just completes the circuit?
Old Sep 16, 2007 | 10:02 PM
HCR13's Avatar
Car: 1987 Trans Am
On the back of the hatch-release button there are 4 wires. black, gray, something, something. I know two of those wires(black-gray) are used to illuminate the switch itself when the gauge-lights are on. The other two are used to open the hatch when they are touched (or when the button is pressed) so I'm pretty sure, but not positive, that its a circuit, 12v-to-ground, being completed. Thanks again...
Old Sep 16, 2007 | 10:29 PM
Toehead's Avatar
Here you go.
If neither of the wires have +12 volts, you can wire 85 to any +12 volt source (fused)
Attached Thumbnails Quick question about hatch switch on bird...-scan0001.jpg
Old Sep 17, 2007 | 08:57 PM
HCR13's Avatar
Car: 1987 Trans Am
thanks alot. I'm going to see if I can install it tomorrow.
Old Sep 19, 2007 | 07:27 PM
Toehead's Avatar
Let me know how it goes!
Old Sep 20, 2007 | 12:10 AM
HCR13's Avatar
Car: 1987 Trans Am
I shall, I haven't gotten a chance to install it yet, I've been busy starting a new job. I will try again tomorrow morning, but if not, then I'll mostlikely get it done this Sat
Dkelz313
Apr 7, 2016 10:38 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
Fronzizzle
Aug 9, 2015 01:15 PM
