Fuse Identification
Old Sep 18, 2007 | 08:00 PM
RehKal's Avatar
Fuse Identification
I've had a problem with an electrical short in my 87 Firebird for awhile now and finally tracked it down to a 15amp fuse on the fuse block. Problem is I have no idea what the fuse goes to. It is located in the very back of the block like it was added to the block as an after thought. The chilton book says the 85 to 89 models are set up with it.
My chilton book shows the fuse in a diagram of the fuse block itself but it's un labeled and I can't find it in the wire diagrams in the book either. The haynes book I have is just about as helpful as the chilton book.
Any ideas what it may be?
(trunk pulldown maybe?)
Old Oct 5, 2007 | 09:47 PM
RehKal's Avatar
Re: Fuse Identification
Ok. Let's see if anyone can help with a picture aid.
http://i14.photobucket.com/albums/a3.../fuseblock.jpg
Can anyone identify the circled fuse? Nowhere in the chilton or hayes book says what this fuse goes to and everything in the car seems to work with it unplugged. There is no identifying marks on the fuse block itself to indicate what it is.
My car is an 87 Firebird Trans Am with a 5.0 TPI engine in it if that helps at all.
Old Dec 27, 2007 | 05:09 PM
faith1's Avatar
Car: 87 Trans Am T tops
Engine: 305 TPI motor
did you get anywhere with your information? i have a fuse pannel that looks just like that and am having problems getting my alternator to charge, I think it may be one of the brown lines that run back to the fuse pannel when the key is on
thanks
Old Feb 16, 2009 | 05:35 PM
milleym's Avatar
Car: 1986 Firebird S/E
Engine: 2.8L 173cid V6 MFI
That should be the fuse for the hatch pull down motor.
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
AmorgetRS
Sep 28, 2015 09:33 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
