Replacement Headlights
Old Oct 2, 2007 | 03:41 AM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
My headlights are getting all rusty on the inside so I think it is time to replace them as they don't look well. Do I have to go for OEM or are there good aftermarket headlights out there, if so can anyone recommend a place to get them.
Gerry.
Old Oct 3, 2007 | 08:26 AM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
Re: Replacement Headlights
I use Silverstars. Nice and extra bright. Made by Sylvania I think. They look and fit like the old ones but are much brighter and have a different color light.
Old Oct 3, 2007 | 08:46 AM
gholian's Avatar
Engine: 2.8 V6
Thanks for your reply. Do you know where you got them so I can order a set.
Thanks.
Old Oct 3, 2007 | 09:29 AM
Elthesh's Avatar
I purchased them at a local store, but I did a quick search and found that Autozone.com sells them. The part number for mine is H4666ST. It may be the same for you, maybe not. Definately check for the correct part and if they will ship to you. Also, they are Sylvania bulbs.
Old Oct 3, 2007 | 09:39 AM
gholian's Avatar
Engine: 2.8 V6
Thanks for your help, much appriecated.
Old Oct 4, 2007 | 03:51 AM
gholian's Avatar
Engine: 2.8 V6
I check a site that sells headlamps and I found that H4666 fits the 91-92 Firebirds only and H6054 fits 83-90 Firebirds. H4666 and H6054 are the style of the headlight. It doesn't say anything about 82 I was wondering does anyone know if 82 Firebird takes a H6054 style headlight.
Gerry.
Old Oct 4, 2007 | 05:07 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Im not sure about them on firebirds, but i have the sylvania silverstars in my camaro and they arre awesome, well worth the little bit of extra money on the others
Old Oct 4, 2007 | 05:10 AM
gholian's Avatar
Engine: 2.8 V6
Did you need to get a coversion kit to fit them or did they just slot right in.
Old Oct 4, 2007 | 05:37 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
On a camaro its a direct replacement, go to your local autoparts store autozone, pepboys and have them look it up for you and then your set.
Old Oct 4, 2007 | 10:13 AM
Elthesh's Avatar
H6054ST is what is listed on the Sylvania site for a 1982 Firebird. That should be the correct part for you. ST in the number stands for Silverstar.
Ghettobird52
Jul 5, 2024 11:18 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
Fronzizzle
Aug 17, 2015 02:52 PM
