headlight switch not working
Old Oct 2, 2007 | 11:31 AM
Mavrick's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: 5 speed
It looks like the relay(?) that plugs into the wires for the headlights that has the pull **** on it is bad as my lights are no longer working. A couple of questions here. First off, what is that part called? Is it in the fact the headlight relay? Also, I know the red wire is power, and the yellow wire is for the headlights, could I just bypass that relay for the time being and hook up a switch between the red and yellow wires? I'm just concerned with possible shorting something out, or worse. Thanks for your help.
Eric
Old Oct 2, 2007 | 11:44 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: headlight switch not working
That's the headlight switch. You can get it at any parts store.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
