Projector Headlights
Old Oct 13, 2007 | 12:52 AM
Red_Dragon_91's Avatar
Car: 1992 Chevy Camaro Heritage Edition
Engine: 305 TBI
Axle/Gears: Stock
ok i found these headlights online and want to know if anybody has them or has seen them, iam gonna upgrade no matter what just wondered if i should go with the projectors, i have them in my BMW and in my truck and they are great
Old Oct 15, 2007 | 08:25 PM
kenderish01's Avatar
Car: 1990 RS
Transmission: a4
Axle/Gears: stock
Re: Projector Headlights
go with them because they are brighter and they look wicked sleek with a camaro. im thinking about them too.
Old Oct 15, 2007 | 08:44 PM
Towman84Z's Avatar
I have HID headlights on mine that i bought off of EBAY and they are great!!!!!Big difference, stock fog light aren't even close to being as bright.
Old Oct 27, 2007 | 09:11 PM
RSChris's Avatar
Car: 1990 Camaro RS
HEY JUST INSTALLED A SIMMILAR SET, HAVING PROBLEMS WITH THEM STAYING ON. DON'T KNOW WHATS GOING ON MINE EVEN CAME WITH A HARNESS I DIDN'T HAVE TO CUT ANY WIRES AND THEY ARE NOW GOING OFF AND ON. THEY WILL STAY ON FOR A LIL WHILE AND NEXT THING I KNOW I DON'T HAVE HEADLAMPS ANYMORE.????????
ANYONE HAD THIS ISSUE.
Old Oct 27, 2007 | 09:29 PM
CanadianRoots's Avatar
Car: 91 Camaro RS
Engine: 305 TBI *355 Coming Soon*
Transmission: 700R4 *T56 Coming Soon*
Axle/Gears: 323
If you are using H4 bulbs in your car the problem has to do with your Headlight switch being overloaded. The stock headlights for the car are only meant to draw something like 55 watts of power and most H4 bulbs draw somewhere around 90 watts. You need to go onto summit and look up the harness that APC sells. What the harness does is it draws current off the battery directly instead of only through the headlight switch thus alleviating the overload on the headlight switch. There are other ways to make it work with relays and such but by far the easiest solution for this problem is the aforementioned harness.
Old Oct 29, 2007 | 12:46 PM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
no overloads here......my HID angeleye lights NEVER cutt off.
they are some bright lights.....they are low beams and lots of people flash-back there highbeams at me. I even have the lights AIMED low. hahah
Old Oct 29, 2007 | 01:16 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I would like to see these lamps on a Camaro before I but them. I upgraded to HIDs a while back, would love to get projector housings though. I currently have E code housings, which are still pretty damn good. I put HIDs in my dad Acura with projector housings, way better then conventional housings.
Old Oct 31, 2007 | 10:25 PM
Bandit5's Avatar
Perhaps a stupid question... but is there any modification required? Or is it just a direct swap?
Reason I ask is because I think you have to rewire stuff to get the H4 to work.
Old Nov 1, 2007 | 01:53 PM
Towman84Z's Avatar
I had to modify the bracket that holds the housing by making the hole in the bracket bigger because the rubber grommet that seals the bulb in the back was to big to just slide in. I didn't have to rewire anything just pugged in the bulbs and haven't had any problems so far and I have had them for about 6 months
Old Nov 3, 2007 | 03:39 PM
RSChris's Avatar
Car: 1990 Camaro RS
the set I bought on ebaymotors, came with short harness to plug and play. real easy. and yeah i had to cut the back of the bucket that holds the lights more to get them to fit. well worth it though.
Old Nov 3, 2007 | 03:59 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
are projector lenses for use with HID or would regular H4 work?
Old Nov 3, 2007 | 04:56 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I think there is a little bit of confusion here. HIDs are not always projectors and projectors are not always HIDs. FWIW, those projector housings up top are worthless. I had those on my bird when I first got it and they do nothing but look cool. They don't actually 'project' the light any different than a free form housing and will just mess with the beam pattern. If you want good projectors you'll have to retrofit them into a free form housing and for all the work you'll do with that, you'll still have standard plug in bulbs. I'd take a little more time and money and get some good (Read: not ebay specials) HIDs. That means, the capsules, ballasts, projectors, and wiring. They'll actually suck less power than those higher wattage h4 setups and put out tons more light.
Start here. http://www.hidplanet.com/forums/
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
