Thermometer stopped working after plug change
Old Oct 24, 2007 | 06:50 PM
Firebird1991's Avatar
Car: Pontiac Firebird
Engine: 305 LO3 TBI
Transmission: Automatic
Hey guys, yesterday change the plugs my self for the first time. I was guided by someone who knew what they were doing. Well everything seemed to be going good, I put NGK V power coppers on, and some O'Reillys wires, but right after the change my thermometer just won't work... While working on the car I notices a write that was not connected anywhere it was hanging right over the manifold, so I am going to try to find where it goes. Also after the change I notice a weird sound coming from the passenger side. Sounds very much like a exhaust leak or a vacuum hose that loose or something. Note I was working being under the car with it being jacked up.
Old Oct 24, 2007 | 10:02 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
Re: Thermometer stopped working after plug change
hahah same thing happened to my thermometer today after changing my plugs but i cant see of feel where it goes any luck
Old Oct 24, 2007 | 11:17 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The sensor for the temp gauge in the dash is between the #1 and #3 cylinders on the driver's side.
Old Oct 24, 2007 | 11:31 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
how does it connect tho?? there is no connecter on the other side
Old Oct 25, 2007 | 01:56 AM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
it doesnt clip on it slides on to it
Old Oct 25, 2007 | 02:30 AM
Engine: 305 LO3 TBI
Holly Crap dude! lol thanks a lot weird but nothing an electrical tape wount fix
Old Oct 25, 2007 | 06:21 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
here is the connector
and here is the sensor it connects to
Old Oct 26, 2007 | 08:26 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
11111
Old Oct 27, 2007 | 02:37 AM
Kevin91Z's Avatar
The metal part of the wire, under that broken plastic cover, slips onto the end of the sensor. The end of the sensor looks like a circle, and the wire slips over it.
Old Oct 27, 2007 | 04:01 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
thanks i didnt think it did i will try and hook it up tomorrow and see how it goes thanks
Old Oct 27, 2007 | 02:33 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
thanks kevin i feel kinda stupid i was tring to put it on the front of the sensor but it slides on it hahah thanks again
1992 Trans Am
May 10, 2023 07:19 PM
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
